Shortage?
Shortage?
Greetings guys, question, what are the signs of my Slash having a shortage? How can I tell if it's a shortage and not something else? Thanks fellas.
I believe electrical, everything is fine up to hitting the throttle, I hit the throttle it takes off, then, nothing, my motor is running, fan is on, but the truck will not move, I have to even disconnect the battery from the ESC to shut it off. I have the low ⚡voltage for LIPO set up correctly, when I do my voltage reading It gives me a proper reading, I'm even wondering if it could be the connectors. Thank you.
Again, If the motor is running/ turning and the vehicle isn't moving then something mechanical is wrong
Is the spur gear turning when the motor is running/turning?
If so then the slipper clutch may be too loose, or there are trans/diff issues.
If it's not turning then the motor pinion could be loose.
