Tamiya Fox
Tamiya Fox
I'm putting together an original Tamiya Fox I'm using a Futaba radio and receiver from another tamiya rc car. but the servos are from the original radio that came with the fox. Now when I move the left stick forward, it goes in reverse...I don't understand. Any ideas?
Welcome to RCU.
Ahhhh, the Fox. One of my RC wishlist's favorites .
What radio are you using?
Is there a servo reverse switch that you can toggle on the transmitter?
Check inside battery compartment if you don't see any servo reversing switches on the outside of the transmitter. Channel 1 is used for steering, and Channel 2 is used for the throttle. Sometimes you will see switches labeled NOR/REV, N/R.
Find the Channel 2/Throttle servo reverse switch and flick it in other direction. Servo will then move opposite from what it was doing.
