Team associated rc8.2e steering issuesSo,
So, I hace a team associated rc8.2e and I'm having a problem with my steering. I have a lot of steering to the left, but not enough to the left. Any ideas to fix this issue.
I was once told, "you gotta turn right to go left." Sorry. Oval track humor .
Was this "not enough steering to the the left" always an issue?
Depending on transmitter...EPA setting got bumped?
If you can't fix the steering throw with the transmitter's EPA, and Dual/Steering Rate, then I'd start from scratch...recenter the servo arm on the servo's spline.
Also make sure that nothing is interfering with the bell cranks or the servo arm. once the battery is in and the body is on there is very little room for all that stuff to move so even a small piece of debris or a stray wire will mess you up. Sucks your having an issue with the 8.2e that buggy is a blast, it's my current favorite!
