NIMH battery question
OK
Hey Gang
I recently bought the Axial Grave Digger for my grandson. I have never had any experience with the 9.6V Nimh battery. So I am wondering if there might be any problems using one in this truck. It comes with an AE-5 Tactic receiver. Any answers appreciated
You'll be fine. What kind of charger do you have? If it's a wall-wart charger, do your grandson a favor, and get a REAL charger so he doesn't have to wait two or three hours for the pack to charge up. (Actually, NiMhs prefer to be left in a CHARGED state, unlike LiPo) A good charger that can charge both NiMhs and Lipos can be had for $50, and will charge a depleted pack in under an hour. You buying from a local hobby shop, or online?
Not sure about reference to the receiver, but the speed control will step down the voltage supplied to the receiver/servo.
Since you are using NiMh batteries with the Grave Digger, you will more than likely have to move the "jumper" (to the right on the ESC) to turn off the LVC (Low Voltage Cutoff).
Not knowing what style of 9.6 pack you have, unless it's a stick-style pack it will not fit in the battery cage. The truck is designed to run on a typical 2 or 3 cell LiPo car pack or a 7.2 or 8.4 v NiMh stick pack.
You will also need to make sure your pack has a Deans connector or "T" connector on it.
As mentioned you will also have to move the jumper on the ESC from LiPo to NiMh.
OK
The battery compartment is adjustable so you can pretty much use what ever battery you like. Seems Axial was on top of that, as I understand all their trucks are made that way.
