Which receiver for this remote?
There is a rebrand of this system called the Turnigy 3XS, more info here:
REVIEW: Turnigy 3XS (2.4ghz car radio) <Updated 16-JUL-2014> - Radios & Servos @ URC Forums
Looks like both compatible Rx's are currently out of stock too:
https://hobbyking.com/en_us/hk3100-3...___store=en_us
https://hobbyking.com/en_us/hk-3000-...___store=en_us
Maybe you can cross reference some part numbers to find them in stock somewhere else, perhaps eBay?
Good Luck!
Good Luck!
every brand (OEM) uses a different syncing (frequency hopping pattern) and is typically proprietary, unless you find a compatible rebrand from the same OEM... HoBao has a rebrand of this system too which I believe is compatible and currently in stock:
HoBao 2.4Ghz Receiver | HoBao Enterprising
It's basically the same as this Rx here that I linked earlier:
Get in touch with Dragon RC or Serpent to help locate receiver. If you gotta jump through hoops to find a receiver, and want to play now, I'd probably tell you to invest in another brand's $39 radio system.
Thanks alot
Here is a cross reference to the Tx's that come with the HoBao RTR's:
HH2.4- 2.4Ghz FHSS Radio (only) | HoBao Enterprising
This appears to be a rebrand of the HK-300 which is a known compatible rebrand, see the product pic listed just below the Rx here:
If you also follow the link I posted earlier on the 3XS, I stated that I no longer recommended that radio anymore and was in favor of the Radiolink system. It appears that the 3XS is probably discontinued and Radiolink may be the way to go if you want long term support:
REVIEW: Radiolink RC3S / RC4G / TS4G 2.4Ghz (Gyro) - Radios & Servos @ URC Forums
RadioLink offers far more features and will stand the test of time when compared to FlySky... I ran into problems with the FlySky Rx's where after 6 months they would start to lose their bind and it got progressively worse until I had to bind them each use. After replacing the Rx with a new one, it resolved the problem until 6 months later, same binding problems came back. I did notice that the Rx's in my on-road cars didn't run into these problems... it was my off-road cars which were ran on tracks with large jumps which seemed to be the root cause of the problem. For those running Fly Sky Rx's on mostly flat land, they seem to do okay, but I've ditched FlySky and found RadioLink to serve me well for all my rental/loaner cars... I run higher quality equipment for the club racers that I run myself
Hey Bill!
Nice to see you here at RCU. 😃 So that Radio Link Tx has proven reliable in the long run, eh? Had to buy very many replacement receivers? And how much are they? I've had to replace a couple FlySky Rx over the years, but not every six months! I was looking at that radio a while back when I was looking for a replacement for the FlySky GT3C I so desperately wanted to work, but for some reason, and I tried several, they would just not work for me. Ended up just binding both cars to my old FlySky GT2, which works well. But if the Radio Link is your go-to radio now, I may have to take another look!
knock on wood... I haven't had to replace a single RadioLink Rx yet... currently own 6 Rx's and they're roughly 2.5 years old... though they haven't seen as much action as they did the first 1.5 years I owned them, but yes I would highly recommend this system as the current best low budget system on the planet, more systems I've compared here:
Which surface radio system is the best? <Updated 24-DEC-2014> - Radios & Servos @ URC Forums
