RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Shocks
Reply
Old 09-12-2017, 12:57 PM
Justwayne
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Shocks
I have a xte pro. The shocks on one
Side of vehicle flop down or compress spring easy somewhat floppy. The other side u can here oil compress and decompress hydraulics slowly. When I run a 2s battery it runs fine. A 3s it sometimes kicks to one side aiming/darting another direction. This is grass yard play by the way. Was just curious if the shocks being blown out one side could cause this or if I should just blame terrain it's a Smaller 10th scale truck. It isn't jumped just tossed a few times when it wipes out so idk how the oil could leaked out
Justwayne is offline
Old 09-12-2017, 02:21 PM
RustyUs
RustyUs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Power will always try and go to the tire with the least resistance when using differentials. To overcome this, and if you have sealed gear diffs, various thicknesses of diff fluids are used to tune the resistance of the internal diff gears.
RustyUs is offline
Old 09-12-2017, 04:19 PM
bill_delong
bill_delong's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if this is a RTR, then chances are the manufacturer didn't properly build the shocks, typically you need to apply grease on all rubber seals throughout the car (including the seals on the shock cartridges)... I would rebuild the shocks and apply a generous coat of grease on the rubber seals and that should do the trick to prevent leaks... oh and RTR actually means "Ready To Reassemble"
bill_delong is offline
Old 09-12-2017, 06:28 PM
RustyUs
RustyUs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
I'd say it's a combination of things causing truck to dance around.
If I recall, the Blackouts have sealed diffs. That's great! But I'm sure they don't come filled with anything other than grease. Filling the diffs with something like 30k ~ 50k diff fluid, and I think you will see a difference in power being put down.
RustyUs is offline
Reply
Display Modes
