Novak brushless
Novak brushless
I want to put a Novak brushless SS in my TXT-1. Has anyone done this. Will it work in that truck. Will the power be good enough?
CA
RE: Novak brushless
What motor setup does the TXT normally run?
I've got the Novak SS system in a XXX4 G+, and its a scorcher. They also make a high voltage version for monster trucks that you might consider.
m
m
RE: Novak brushless
If I remember properly the ss is equivalent to a 10 turn hand wound brushed motor which is the same (if not more) power than the two 27 turn stockers that the truck comes with. However it makes that power at a much higher RPM and thus delivers alot less torque than two 27 turn motors running in parrallel. If you run alot smaller pinion (less teeth) with a single ss, you should get similiar performance to stock with all the advantages of a brushless setup. The other option is to run a dual ss setup and that would be a absolute animal. Not cheap though.
RE: Novak brushless
ORIGINAL: Hyrax
RE: Novak brushless
Yes torque output is my biggest concern, I don't think the HV-maxx brushless motor will fit but I'm not sure. I'd like to use the bigger one if it would fit.
RE: Novak brushless
The TXT-1 is considerably heavier than most applications the Novak SS is normally being used in. I'm just concerned about the truck being to big for that setup. It is about 12 lbs.
