motor problem
motor problem
I am having a prob with one of my motors. It used to have the low end torque to push the car. Now it only turns the wheels when they are in the air, not on the ground. Who knows. It used to make the car go extremely fast, now when the car is on the ground it won't turn the wheels. Lift the car in the air, they go just fine.
Any ideas? Thanks.
Any ideas? Thanks.
RE: motor problem
Maybe your motor brushes have worn out to the point that it is not pressing tightly against the commutator. Try replacing the brushes and see what happens.
Joel M.
RCCarTips.com
www.rccartips.com
Joel M.
RCCarTips.com
www.rccartips.com
RE: motor problem
Forgot to say - this is a sensorless brushless motor.
Thanks for the input. I now think the motor is fried. I am going to take it back to the factory and get a new one.
Cheers.
Cheers.
RE: motor problem
maybe you put the diff the wrong way around
diff too loose
uh don't know don't ask me i THE NEWBIE...
na man just kiddin
but see if ithe diff stuff is whatever yall
diff too loose
na man just kiddin
RE: motor problem
Thanks - But it is not a diff issue. Nothing wrong with the car itself. Just the one motor. So this coming week i will drop it off at the factory and get a new one.
RE: motor problem
At first only 6 - I was using it on my Schulze ESC before it blew and it was doing this. I have a new ESC now and still does it.
Hold the car in the air and all is fine, put it on the ground and just jerks and does not go at all. put my Lehner back in and all is good and works.
