Man I'm tired of this.
GA
I finally got my twin detonator one link crawler project into a form to where it can actually move, so I decided to through on some electronics and give it a test run. Well ater discovering that my electronics didn't wrok I got out the trusty volt meter to start narrowing down what the problems could be. It came down to the receiver. I was getting volts coming into the receiver but it wasn't giving any power to the servos. So I switch out the receiver and radio and same thing happens. What gives?[:'(]
GA
RE: Man I'm tired of this.
Right now I have an MSC on my twin detonator(Can't afford the evx). Also, whats an Rx plug? Is it a crystal or something? Sorry to sound dumb but I'm mostly a nitro guy.
Banned
Nitro guys have rx plugs too.. It's the black plug on the end of the wire coming from your speed control, that plugs into the rx. My bet is that one of them is bent/distorted and isn't grabbing the pin when you insert it into the various rx's.. Just cuz your VOM can see the voltage, doesn't mean the pin is getting any. Push the little tab down and pull the jack out of the plug. Make sure it seems right compared to the others. It's also possible that you've got the plug in backwards. It can happen. Verify that.
