ok, whaddaya want?
#51
Banned
RE: ok, whaddaya want?
You crazy Canadians! Sounds like sumthin they'd do in Iowa
Yeah, I'd run a gear cover in that situation. Threadlock is probably overkilll though.
#53
ON, CANADA
ORIGINAL: S.A.E.W.O.T.
i don't run a gear cover! and i run rrp gears! and i have no probs!
#55
ON, CANADA
well, to an average basher or club racer, they may not notice the slight change. But to serious racers, they feel a wide band of change. I dunno, when I drive without my gear cover, I personally feel I drive more consistent figure-8 laps around mine adn the neighbor's driveway. And when I run a gearcover I also feel a sense of security. so when I find out the spur is stripped, I will most likely know the reasons for stripping. and without a cover... gah... I drove without a cover before... I drove full trigger into my neighbor's 1/8 scale Radioshack hummer... the hummer broke the front arm... not too shabby them radioshack guys... but xmods are not bad... anyways, my motor ejected from it's position and wasn't touching the spur at all...
#56
Banned
ON, CANADA
DON'T HIT STUFF! and make sure ur screws r tight! im always hittin stuff and breakin' parts but not once did my motor move!....hmmm? and what happend if u got a lil pepble in side the gear cover?...it's gonna mess ur gears right up! and i go thru mud, dirt, gravel, grass.. all that and, i still have the oringinal rrp 87t spur i got 4 my evader like 4months ago, and i still have the 19t pinion that i got at the same time as the spur and i do NOT run a gearcover
#57
ON, CANADA
You're not a racer, that's why... but you still have a better chance of fscking your gears. the RPM gear cover for the B4 and T4 are as bulletproof as the Stealth transmissions themselves...
#58
Banned
With the SS5800s in my trucks, I may run one this year. But, if I end up ditching the Novaks, and going back to brushed motors, I know I won't run one. I change motors too often on raceday to be screwing around with a gear cover.
#59
Banned
ON, CANADA
thats what im like speed i have 4 diffrent motors and im always tryin' 2 make them the fastest they can be with diff gearing and brushes and springs and irun my bl some times!, so that basicly y i don't run 1!, cuase it's a pissoff always takein off the gear cover!
#60
The cap on my stock gear cover came off and I didn't notice it right away and some small stones got in there and muffed up the gears big time. I wish that I had the RPM gear cover before I destroyed my gears good thing parts are so cheap. Just waiting for it to show up so I can get rid of my [expletive] stock one that now has duct tape over the hole cause I can't find the cover that fell off. What a hunk of junk to put on such a nice kit.
Edited, The use of inappropriate, offensive language or language substitutions are not permitted on RCUniverse.com.
#61
CA
ORIGINAL: juleous
First of all, we dont know what car you have. And second of all, it is your fault that the cap came off so dont call it a [expletive]. I put a little shoe goo so it slides in easy but bonds to the gear cover, and if i need to make an adjustment, I take the cover off, 3 small screws.
