comm help
ON, CANADA
RE: comm help
There are 2 sizes of comms for 540 size motors, small ( 7.5mm/0.295" ), and medium ( 9mm/0.350" ). (These are the sizes when new). You can get away with 0.270" on the small comm but 0.275 is recommended as in some cases the copper could grenade. For the medium comms, 0.310" is the minimum, (with 0.306" being the 0.270" minimum equivalent).
ORIGINAL: B4rcracer
what is the diamerter of the comm when u have to trash it
RE: comm help
yup, agreed. i even try to find magnetic center so that one end of the arm isnt pressing on its shims harder than the other end. i use those teeny tiny brass ones from trinity although im lately becoming anti-trinity due to every time i order something from them, it seems to be packaged incorrectly, like single shunts on dual shunt brushes. they even said dual shunt on the package. its a pretty funny story, i called trinity about it and told them that they were labeled dual shunt and that they were only single. the trinity rep said"are you sure". i started laughing a little bit and it seemed to ruffle his feathers. i responded by saying "im not an expert, but i can count to one.
ps. i also got some brush springs that were labeled wrong from them.
CO
RE: comm help
That, of course, depends on how deep you have to cut it to get a clean surface. The ultimate determination is the diameter. The thinner a cut you can get away with the more times you can cut it. I've been told that an comm will actually last longer if you cut it regularly than if you wait until the performance drops off. Comms can get out of round if you wait too long between cuts then you have to take off quite a bit of material to get back to round
RE: comm help
it depends entirely on how often you cut them. i cut my chameleons every 3-4 runs. if you do this, you only have to skim about .001-.002. so i get about 12-15 cuts, maybe more. if you wait till you notice the motor getting weaker, you have to cut much deeper, and you would be lucky to get 5. it also greatly increases the brushes life to cut often. in most cases, your motor will wear as much on the 5th run as it does on the 1-4th because the wear rate becomes progressive. as it wears, it does so much faster with each consecutive run.
My Feedback: (325)
RE: comm help
end play is the amount the shaft will travel when forced one way and then measured forced the other way. I usually center the comm in the field, but really never saw a spec on the minimum end play on the shaft. I was thinking more like .010" total ?
I supose any amount is good as long as it doesn't get to zero at some point. Maybe there's no standard?
