Evader Motor Question
NY
Okay, I see lots of support for the Reedy Quad Mag here in the forums for a 19t motor. I'm currently using a chameleon pro 2, that wasn't broken in correctly at all (we all learn somewhere), and a duratrax 16t ESC. My question is this: Is there anything better (read: faster) than the Reedy down to 16t, for use with an Evader Pro ST?
MI
RE: Evader Motor Question
If you don't plan on racing, end the madness and go brushless. The prices are coming down. I bought a used Novak 5800SS this past spring and used it (a lot) all summer. No maintenance whatsoever...and fast!
TX
So, to answer your question: No.
The Spec Modified 19t motors like the Chameleon or the Quad Mag are actually FASTER than most 15t motors. ( it has alot to do with construction, components, and brushes ).
I run nothing but brushless in all of my trucks, except for my Tamyia Hornet. Entry level brushless systems ( with similar performance to the 19t spec modified motors ) start at $165.00. Faster Brushless systems can get as high as $1000!
The Novak SS4300 will give you similar performance to what you have now, but longer run times.
The Novak SS5800 will give you faster performance, with similar runtime to what you have now.
Novak GTB/Velociti 6.5 will give you much faster performance, but with reduced runtime.
