supper brain 959
OR
supper brain 959
have they fixed the over heating problim on this charger yet?? im thinking of geting it for my mini's. it will mostly be charging 2/3A 900~1100 cells at 1~2A curent. if they fixed this charger please let me know this will be my universal charger for every battery pack i own. i dont own many packs but i will have a few good 1100 sport packs for my new Rc (2/3A) and there rated to charge at 1~2A curent so i wont be realy useing my charger hard but just makeing sure this is a good charger for what i will be doing
My Feedback: (325)
RE: supper brain 959
It's a great charger for doing 2/3 A packs because it will not get hot. They have not changed it so it would still get hot doing today's 4200's at 4.5 amps (especially back to back packs)
A digital piranha is also a very good one for doing mini batts and a bit more versatile also.
OR
ooo ya im on a budget but for 2/3A packs and it not over heating thats a good thing i live in oregon it can get hot in the summer but it gets very cold in the winter. my house is useuly around 68degrees and i wont be afording any 4200 packs any time soon. i do have a 1500 ni-cd pack for my roto start but i have a ni-cd charger for it that works its mecanical but it works so from what i can tell this will be fine for my little Rc plane with its 900mAh pakcs and my mini with its 1100~1500mAh packs all 2/3A
OR
thats what i was thinking maby doing 2 makeing a fan that runs off the mrc its self but i doubt it will realy get hot enough for problims useing it for 2/3A packs at a decent curent
OR
so ya i guse im going to go with the MRC 959 just because im pretty much going to use it for 2/3A cells and thats probly it for what it will be seeing so it should all be good correct? o and how easy is it to set it up for charging not too bad set curent and battery type and it will peak out and be done
My Feedback: (325)
It's very easy. For your minis you will just have to change the default current setting to 1-2 amps and push start. For the 1500 subC packs you will have to change the default mv setting to 50-70 and push start.
OR
sweet, ya im geting some of these ultamate RC sport packs for 11$ and there like very good sport packs and there rated to be charged at 1~2A curent says to charge at 1.5 for the 1st 5 cycles or so. then u can charge at 2A but to just watch the temps of the pack if it gets realy hot to just disconnect it but i will be takein care of them. im thinking of makeing myself 1-2 custom GP1100 2/3A race packs for my mini when it arives soon. im plannin on haveing around 3~4 packs for it 2 sport 2 race or 2 sport and 1 gp pack it just depends but if this will do the job you cant beat 45$ and i got a good 25watt soldering iron for like 20$ brand spanken new for my new mini
