Unofficial Hot Bodies E-Zilla Thread
#501
RE: Unofficial Hot Bodies E-Zilla Thread
thanks for all the advise guys!!!!!
do u no if a R152JE rx will work with the stock esc?
i like the sound of the jr xs3 the most but i cant find anyone in the uk who seams to have one!!!!!! can anyone help?
#502
Wow!! This is a fantastic thread for the E-zilla. Here is a link to the thread i have created for my own E-zilla as well, do check it out. http://www.daddyhobby.com/forum/show...t=16609&page=1
#503
well, theres not been much interest in thistopic recently... so i thought id start it up again with a question...
anyone know of a 2speed transmission that fits the ezilla? i dont mind a bit of custom fitting...
#505
well i emailed traxxas 2 see if they actualy sell the 2-speed from an e-maxx on its own... they dont... [][]
soooooo, i guess im back to looking on ebay...
#506
SC
I was tightening the slipper clutch on my E-Savage and realized that 7 out of the 8 shocks had a little bit of oil on them.
Did I bust them allready? If so should I get new ones or should I rebuild? If rebuild where would I get the items.
Thanks!
Thanks!
#509
if its just the shock shaft that has a a thin sort of coating, then its just normal. the seals wont stop every bit of oil from escaping.
ive had an obvious broken seal on my street weapon for months... cant replace them on an old car... i just clean it and refill the oil every couple of runs...
if i had 7 broken seals, id just buy a new set of shocks. probably aluminium threaded shock, as they allow you to hange your ride hight by just turning a few screws basicaly...
ps. if your jumping your truck a lot, i would also considder getting piggyback shock...
#511
SC
It's barely leaking. I just noticed it because dirt got up there and it just clustered around the bottom of it.
I think I will hold off on shocks until more come out that are made for e-savage specific. Since I'm not sure what the differences are in the savages and the e-savage.
#512
yeah... im sure theres nothing wrong with them, they do leak a little normally. if you havent already got them, you should DEFFINATELY get some shock covers. cos its the dirt gathering in the leaking oil that causes the seals to break. just get a set of savage shock covers off ebay for a couple of quid... and the best bit is... U CAN PICK THE COLOUR!!!!! WOOHOO!!!!!! lol
there are already shocks available specificaly for the e-zilla/e-savage, there usualy on ebay aswell.
and the savage shocks are 2cm longer than e-savage shocks, so might not fit propperly.
#513
hey hey guys... look what ive found...
[link=http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=003&sspagename=STRK%3AMESE%3AIT&viewitem=&item=130062918653&rd=1&rd=1]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=003&sspagename=STRK%3AMESE%3AIT&viewitem=&item=130062918653&rd=1&rd=1[/link]
#515
GA
ORIGINAL: AznBash3r
wait, i do not get it...how can you take the broken c-hub and switch it to a non broken c-hub? wouldnt the broken one still be non functional if its broken? its kinda confusing. anyways, the a-arms will not break, thts the least possible thiing to break, even from severe bashing.
#516
[link=http://www.youtube.com/watch?v=b9EPzQlxhxw]video[/link]
got a little vid for ya... it goes a bit dark at points cos my camera isnt great...
HOPE U ALL LIKE IT!!
#517
hi guys... after looking around finally decided to buy a e-zilla RTR version as my first "real" rc. I'm a rookis in the rc world, so I would like to ask for some advice on what to do to maximize my experience and take the best i can out of this off-road that everyone praises about.
#518
well firstly get new shocks for it... the stock ones are far too soft. get a set of 4 purple savage shocks and put one on each corner, so you have 1 red and 1 purple on each wheel.
if you want more speed/power, upgrade the batteries to 7 cell hump packs, make sure thay are at least 3000mah cells. if you do get bigger batteries id also get a savage wheely bar, just incase...
if i were you when you first get the truck, before your even run it, take it appart into little peices and then put it back together. it might save you somemoney. sometimes the diffs arent installed properly and they will destroy themselves.
put a fan on your esc to help cool it down and a bigger fan over your two motors (not a little one on each).
i also upgraded the servo to a high torque, something over about 5kg should do the trick. the standard servo wont turn the wheels when the truck isnt moving.
#519
Are you wanting to buy an old e-zilla or the new E-Savage. Basically the same thing but the zilla is discontinued! I have broken a c hub already along with frying an esc (my bad ) PLUS i cracked the whole front ride side, but i super glued it and its all good right now. I'm EXTREMELY hard on everything i own though. the E-savage is the best stock electric monster truck on the market, it kicks the crap out of my E-Maxx!
Get 7 cell hump packs
no need to upgrade the servo in my opinion it work just fine.
if you want it even faster then buy 2 S-600 motors and a 21T pinion gear
#520
E-Savage Goodness:
Mine is completely stock, Got a great deal on it used so I had to pick it up. Couldn't resist the lure of an Out of the box, 4wd, MT that was electric powered.
So far it's been way to cold to run it, I don't want to snap shafts in the freezing temps.... But soon, hopefully.
#521
just had mine out in the snow... got a [link=http://youtube.com/watch?v=05gRCXB-AN0]video on youtube[/link]
no need for a fan to cool the motors... just pack them with snow!!!!!
#522
MA
Is there any way to get rid of that horrible stance up front? The E-Savage always looks like its front end is broken because it's pitching forward so.
#523
i didnt like it either, but you kind of get used to it... you can raise the body at the front to make it look better at a glance... or you can put stiffer shocks on the front to raise it up a bit. oooooor you could remove the suspension clips off the rear or just put some more on the rears.
#524
ORIGINAL: Yub, yub, cmdr!
The short answer is No, it's built with a forward leaning stance in the chassis. Yes, you can adjust pre-load or raise the body, but essentially that's the design of the chassis.
Kind of a take it or leave it thing.
#525
yeah but u get used to it after a couple of runs. and unless your looking at it lying on the floor, you cant tell anyway.
