xb rising storm
xb rising storm
ok ....hi everyone . This is my first post and ...well .....i am new so NO flaming ok .....tell me nicely if i do something wrong.....Right . here's my situation. My missus bought me a tamiya xb rising storm for xmas. Worked ok ....so i decided to hop it up to the max. I bought a fireball 17 turn motor, M Troniks ESC Viper RV15, Superstreet wheel conversion, some 7.2v 2300 mah batteries, every metal bracket and hub u can think of ..anyway....i am getting away from the point. this car now flies. for about 5 mins that is. the esc seems to reset itself after that amount of time. i have been told that that the mtroniks viper is a ***** to setup but i am sure i have done everything to the letter...... if anyone can give me any detailed help as to do this properly i would be very grateful as the guys at the mtroniks website are pretty much a waste of time.
Thanks in advance
Thanks in advance
RE: xb rising storm
When you got the 17T motor did you put a smaller pinion gear on it or are you still running the stock 19 tooth pinion. If you are still running the 19 tooth pinion, you probably want to put on a smaller one. A 15 tooth would be a good place to start.
RE: xb rising storm
Well I don't know what the internal gear ratio is on the Rising Stom is, but you are most likely over geared running a 19 tooth pinion on a 17t motor. That is likely why you are thermaling your ESC.
ORIGINAL: fozzy1
yeah am sitll running the 19. i just wanted it to run properly before i upgraded anymore.
RE: xb rising storm
ahhhh .....u learn something every day....nice one ...i will buy a new pinion for the motor and c if that works. cheers dude
RE: xb rising storm
ORIGINAL: fozzy1
My Feedback: (34)
RE: xb rising storm
WHOA!!Before go and by a 15t pinion realise that 1. yes you are overgeared, but 2. the gearing setup on the rising storm will not work with a 15t pinion. I've tried lowering the gearing, and in every possible possision the gear mesh is never correct, resulting in stripped spur gears. You'll need a custom motor mount to change the gearing, really. Besides that, the lowest you can really go is 18t.
RE: xb rising storm
its a good job the shops are shut. lolol .......dont worry guys ......i will wait and take the car to a shop and find out exactly wot is wrong. thatnks for the advice......was very confusing .....and enlightning at the same time........i might just go and buy a faster car ....that looks really good....lol
My Feedback: (34)
RE: xb rising storm
I bet what's exactly wrong is just the overheating.....oh well. The stock gearing made my 27t motor go like 32mph. It's so high i can only run that motor in the winter kuz it gets so hot.
RE: xb rising storm
ORIGINAL: tamiyacrawler
My Feedback: (34)
RE: xb rising storm
At a club level it is very possible to race,and i have seen someone run it at regional level with success; if my track holds 4wd buggy i will surely race it. All you need is the 67t spur, bearings, a dremel(hacking off some stuff for weight loss) a good motor, and some driving skills. It poses a few problems compared to the other 4wd bugs though.
1.) gearing options are limited
2) no toe/camber adjustment.
3.) Bottoms out quite easily, but this can be fixed with some fuel tubing on the shock shaft.
If you want to get pretty serious with it you'll want to get some cvd's by Yeah racing and the aluminum steering kit.
