tc4 upgrade to 100mph
My Feedback: (-1)
RE: tc4 upgrade to 100mph
fusion, though 100 is only a bit higher than 65, it will take a hell of a lot more power to get those speeds. Expect to see speeds of no more than 75.
CA
Even 75 would be cool, I could imagine on controlling that speed. What I'm trying to find out is how to build it to get that fast. Have you heard or recommend Plettenberg motors?
MA
I've never heard of those motors but a 5 cell lipo pack will fry most esc so you'll have to buy a really good one from some tiny company that makes unusual R/C stuff
#32
PA
Lipo batteries are NOT batteries for the new rc'er. You need to take extreme caution with lipos, charging rate has to be just perfect, and bashing even a little is out of the question.
Lipos are very dangerous and if charged at the wrong rate, or hit hard by a crash, will explode... and you don't want to be anywhere areound when that happens. Your car will be ashes.
This is what I suggest:
Low turn brushless with correct gearing (sphere neo combo is sweet)
High capacity IB3800 cells from boomboombatteries
I am not trying to turn you awau from lipos, just trying to save you, your car, or even your house.
Be extremely cautious with lipos. (Very few people on these forums run lipos)
Read on some of the cautions about lipos [link=http://www.*********.org/lithium_battery_breakthrough.htm]here.[/link]
I don't know why you want to go 100mph. Which you will never get to considering the speed record is 111mph, with a RC10L3 pan car. At speeds of 65+mph, the steering would be ridiculous, and you'd need a big open sspace, like a vacant parking lot to run the thing, with finess on the throttle.
Just keep in mind that lipos are NOT for in-experienced rc'ers, and you will need a new charger.
#35
MN
This thread is interesting. I just bought a new Schultze U-Force 75 ESC last week and a new Hacker C40 6T motor yesterday. I'm gonna go for the ultimate top speed with my TC3 this summer too. Someone a number of posts ago said that the Hacker motor should really only be used with up to 8 cells. Is that true? I've had guys at the local hobby shops and at the track tell me that you can easily do 12 cells with that motor without a risk of damage from heat. I was planning on using 10 cells. I always go a little below the maximum capacity. [sm=rolleyes.gif]
#37
MN
Hey Cadillac have you ever used this combo that I'm going with? Did you ever experience any glitching at all? I just wonder because last summer I was using my SS5800 brushless setup in my TC3 with an Airtronics synthesized receiver and it glitched so bad I could hardly drive it. Hopefully this setup will be more drivable! [sm=biggrin.gif]
#40
CA
ORIGINAL: 99GTP
#41
MN
All together with shipping the motor and controller ran me $465. I was thinking about getting the Hacker controller but when I called them they said they're not selling them right now and are testing some new prototypes. He told me they are trying to come up with a smoother system that's easier to drive and ROAR legal so they can get into that kind of racing. My goal here is just to push the car into the 70's somewhere. I would consider 80mph a miracle with the setup I'll have! [sm=biggrin.gif]
#43
ORIGINAL: Evader 53
also, speed records mean nothing, they are ment to be broken so how can you say who will or will not break a record??
there are some monster trucks over at rc-monster that can hit in the 70's. so a 70mph 8lb moster....a 3lb 100+ touring car isnt that much of a stretch.
keep this thread alive until i can get a 65-70 mph run in a stadium truck and then say what wil NEVER be gotton to by someone. sorry for the ranting, but that really pisses me off to say that somebody will not be able to break that record when it is very likely they could. a tc3 loaded with cells got 96mph, a tc4 with the same voltage but in lipo would defiantly break 110mph.
#44
MD
The biggest problem to overcome is finding a suitable location. Most asphalt parking lots are not perfectly level and once you get over 50 MPH even a pebble can lift the front end enough to send air under the car and send you flipping end over end. Most of the R/C speed records were set on a large oval bicycle racing track which has an exceptionaly smooth surface and sweeping banked corners. I think you would almost have to have an oval type configuration to hit 100mph so you could gradually build speed over a few laps and be able to keep the car in radio range and be able to see ahead of the car to drive it. Running in a straight line the car would go out of site and radio range probably before it could even hit near 100.......
#45
CO
To get top speeds with a TC you'll have to be careful of what body you choose. The Stratus is indeed a favorite among the racers but that is because it makes good downforce to make it corner better. You'll want something with less downforce (especially something without that big rear wing) to keep down the ground friction.
The catch is that a slippery body will make it more than a bit squirrely to handle at high speed even if you get the toe and caster just right so some driving finess will be required and you could get into big trouble REALLY quick (as in ' I just crashed the car - where's the dustpan so we can recover some of these parts?!').
If it's truly pure top speed you want and you aren't concerned about cornering I'd also go with rubber slicks (and hard ones- maybe a compound somewhere in the high 30s) to keep down the tire to surface friction. Even the hard compound foam ones will slow you down because they grab the ground too well. Also remember that at the kinds of speeds you'll be turning the wheels you will need to be very careful about getting the tires mounted perfectly or they will vibrate like madness. They will also grow quite a bit in diameter as the rubber stretches (ever see a top fueler do a burnout?) so make sure they are glued on very well and make sure that you have plenty of clearance for the extra diameter.
#46
MN
I just got my new Schultze U-Force 75 ESC today. I wired it up to the Hacker motor and it seems to work ok. There is one very strange thing that happens that I can't figure out. I read that if you turn switch #3 to the on position the ESC will provide reverse. I did this and I can get it to go in reverse but then after that it stops and the motor won't go anymore in either direction. The steering still works just not the motor. Has anyone ever heard of this happening before? [sm=confused.gif]
#47
MA
yeah that happened to my duratrax intellispeed and since it was out of warantee and it would cost about $20 to fix it I junked it and bought a GTB! I think I may have caused it to fail by CAing the on off switch to the ESC case... hope you didn't use CA glue anywhere near your ESC cause I know Novak doesn't cover that under the warantee...
#50
OH
kinda bumping the thread a bit im interested in the newest developments in these im interested in making a tc3 keep up with a nitro race im thinking a max amps 8000 mah lipo 7.4 v and a brushless system I dont have to be faster then them but i need to keep up and i woul;d win i think because i would not haveto pit during the race what is the best bang for the buck combo going now. speed and price? this will be in Tc3 cars prolly racing against ntc3s also
