The Evader Coalition ~ T.E.C.
IL
RE: The Evader Coalition ~ T.E.C.
i did the same thing so far so good for me just make sure its a locknut but i need a new plate as well as it is still a bit bent from my 45mph crash a while back
VT
yeah i got one on now + locktight but i think i'm gunna grab one of the ones with a heat sink just too...
the lug
the lug
CA
Wait, wth?
How does that bind the gears? Smooshing the motor? Sigh, I really didn't wanna take the Savvy apart again!
VT
ORIGINAL: rawfuls
Wait, wth?
Wait, wth?
the lug
IL
ORIGINAL: rawfuls
Wait, wth?
Wait, wth?
VT
Banned
VT
hey im ordering the mamba max 7700kv, what should I be expecting? I am also switching over to deans plugs for my batts. Should I just cut the tamiyas off and soler on the deans, or should I discharge them or anything?
VT
YOU NEED TO CUT 1 WIRE AT A TIME, if you do both you'll short out the pack and it'll be near worthless, and i have the sidewinder 4600 and that is crazy fast, the 7700 should be insane...
the lug
the lug
IL
ust know ull never be able to go to a 3s lipo with that motor. ull need a 5700 or lower kv. but if u are just running 6-7 cells or a 2s lipo u will be fne
MI
don't go with the 7700, you are losing a ton of programability because you will have to gear down. that motor is meant for light on-raod cars like the TC4. here watch this [link=http://www.youtube.com/watch?v=SpcgGd9GJ8A]video[/link] it makes more sense.
I am sure this has been covered before, but I am not checking out 500+ pages to search for it, so here it goes.
I bought a Venom Fireball motor for my Evader and it's dead after running it for about 12 batteries. I am going to return it and I want to know what is a good 17T motor to get in the $30 range.
How do you tell what is good from the little descriptions? Here is an example of different motors in the same price range, how to know? By the way, I use the truck on road and in the grass, all over. I don't race, just having fun.
Associated LRP GT3 Turbo Motor 17T
http://www3.towerhobbies.com/cgi-bin...?&I=LXLRD9&P=7
Reedy Flash Modified
http://www3.towerhobbies.com/cgi-bin...?&I=LXJZN4&P=7
Associated LRP V10 Spec.4 17T
http://www3.towerhobbies.com/cgi-bin...?&I=LXLRE6&P=7
Associated Reedy Radon 17T
http://www3.towerhobbies.com/cgi-bin...?&I=LXMUN9&P=7
Epic Intense Modified Motor 16T
http://www3.towerhobbies.com/cgi-bin...?&I=LXJNG5&P=7
Team Orion 17 Turn Double Formula SV2 Pro
http://www3.towerhobbies.com/cgi-bin...?&I=LXJAK3&P=7
Any other suggestions are welcome.
By the way, I am using the stock ESC, is it possible that has something to do with the motor dying, or is it that the motor is a piece of sh*t?
Many Thanks,
Ian
Many Thanks,
Ian
PA
cheech whats is a good lipo battery -orion 2sp any good,do you know anything about a venom
ac/dc charge with balancer its like 149.00 to 179.00 depending where you buy it,i have a novak 10.5 with sintered rotor and xbr esc, also for dirt track what pinoin and spur would you use ,you are the expert from what ive read on here.
I need advice on a Lipo for an Evader, MM 5700. I need 30 minutes in the Main. Some guys use maxamps 8000 at the track, but is there anything comparable in performance, but cheaper in the wallet? A 4700 NiMH barely makes it, and slows at 20-25 minutes, so I need an upgrade.
NY
i have heard good things about track power or flight power. orions definetly top of my list... SMC makes a good lipo, SMC just makes good batteries period. the associated reedy lipo looks promising. as far as the charger it looks good, but at that price range i would look into other brands like hyperion
VT
ORIGINAL: cheech4
as for motors from above all those are good, but if you'll be willing to go to a 19t AE's challenger is a pretty good motor
the lug
CA
TrueRC guys, plain and simple.
Their packs don't look great, but pop it in, and it blasts.... It's insane.
The hardcased = even better! Although, it's only found 5000mAh in a hardcase.
truerc.com
truerc.com
For someone that has never done anything with shock oil, is it hard to change the first few times? I know that when you fill the shock you're supposed to wait for the air bubbles to come up. Is that pretty much it??
OK, I stripped my B2 diff. (insane acceleration) Im going to buy a metal diff in arrow rc but it gets too long to have it in home about 5-8 weeks. im going to buy another B2 diff and a the metal, I need to adjust the slipper clutch, is difficult t adjust that?
IL
no i usauly just tighten it some then hold the spur and push it accros the carpet till i feel there is good resistance but not too much
