The Evader Coalition ~ T.E.C.
#1302
CA
RE: The Evader Coalition - T.E.C.
ORIGINAL: discgolfer72
yeaa itsa the diff gear cameras outside or id take a pic real quick you know me i like speed
the center of the diff gear is complety unattached where the little dif balls go its sposed to have several holes for thoes balls whell now its just a big hole all the way around
It sounds like the diff wasn't adjusted right to wear out the middle.
#1303
NY
im still curious how fast my new set up will be on the evader with the revolution double 13t from team orion. does anybody think i will gain anything like 5ph maybe 10mph.....?
#1304
CA
ORIGINAL: cheech4
I'm guessing about 7-8 mph if you had the photon motor and about 6-7 over the havok motor with run times about 1/2 of what they were.
#1305
NY
ORIGINAL: raz54
ORIGINAL: cheech4
i guess its time to buy more batteries,,, lol
#1307
NH
ORIGINAL: jedisolo
The tires are 2.2 inch's tall. They are a little taller than the stock ones.
#1309
NH
ORIGINAL: jedisolo
Crash7772,
they are about 3.5 inches.
Crash7772,
#1310
NY
ORIGINAL: Crash7772
Well stock tires are about 3.8" tall and 20/88 is the ideal gear so figure the new ones are 4". I would use a 18/88 gear for starters.
ORIGINAL: jedisolo
if the tire is bigger wouldnt you go with a higher tooth pinion, more teeth = more acceleration, a bigger tire needs more time for it to make a complete rotation, so if the tires are a little bigger then u would need more teeth to accelerate faster. i would think so..
#1311
NY
ORIGINAL: cheech4
ORIGINAL: Crash7772
ORIGINAL: jedisolo
you answered my question already, lol
#1312
NY
ok currently im runny the stock havok motor on the evader pro... when i run it it runs hot, but after a while of run time. is that normal?. where do i check the motor to see if its hot or not the can or the endbell. its the endbell that gets hot the can is cooler. also when i get the new motor should i get a new pinion also, like i said before in a prior post, i installed a robinson spur 87 tooth. along with the alloy idler.
#1314
CA
You should be able to hold your fingers against the motor for at least 5 seconds, if it's too hot for that it's too hot. Most motors will get pretty warm but if it is getting too hot you need to put on a smaller pinion.
#1315
NH
ORIGINAL: raz54
This is what I use.....
http://www2.towerhobbies.com/cgi-bin...&I=LXFWJ4&P=ML
http://www2.towerhobbies.com/cgi-bin...?&I=LXJY51&P=7 (this is a different series but I use Trinity)
http://www2.towerhobbies.com/cgi-bin...&I=LXUE64&P=ML (similar)
http://www2.towerhobbies.com/cgi-bin...&I=LXJY55&P=ML
Check out RCBOYS on ebay for some of the listed above or next time you order from Tower add these if you don't have them. Clean your motor every 10-20 runs on average, keep in mind more often is better. I usually clean it every 5-10 runs personally. Proper motor care will keep/increase power and produce longer run times. As stated the ideal gearing for the stock tires is 20/88. Taller tires will require a smaller pinion. Smaller tires as I run require a larger pinion. The stock gearing on the Pro's is to low IMO (under gearing can be just as bad as over gearing). When thinking about gearing just think of a pedal bike. The biggest sprocket on the crank and smallest on the wheel create the most speed. The crank=the motor and the wheel=the spur.
#1316
CA
[/quote]
I always thought it was under geard too. I run a 15 tooth in the sand but go up to a 17t on pavement and the motor doesn't even get warm both with taller than stock tires.
[/quote]
#1317
ORIGINAL: raz54
not really the middle it burnt out where the dif balls go its like they ate away the plastic in a perfect circle all the way around the diff gear it was setup right its just from using my 9/11 turn it has happend to my rc10t to the 9/11 turn will actually melt the clutch balls into a spur gear the mostly the 11 turn for some reason
its faster than the 9 turn and seems to have as much torque as my 27 turn green machine (its a reedy ultra and where i bought it said it was a mr.t's modfied)
that s the first that melted like this other two had the teeth burnt off but one was stock and second one was replaced by hobby store (stress tech waranty)
#1318
What happened to your diff gear this last time is a result of it slipping. When it slips things heat up and those little balls get hot and slice through everything. That's how you ended up with two pieces. That indicates one of two things or both, too much power or the diff not tight enough.
The metal diff gears are tough to find right now. Try using a nylon diff gear for the B2, they are more durable and if you tighten it down good it might help. Are you using carbide balls, they should be better too.
Duneslider
Duneslider
#1319
thanks i had it pretty tight so im guesing its power didnt start haveing this problem till i ran that 11 turn reedy ultra and now its 2 cars with the same problem from the same motor. i was wondering if the associated ones would work my rc10 t diff gear looked the same but the evader one looked a little bigger
is the ass part number for that gear 6580 and the metal gear what is it for is it made for the evader or is it another car
no not running the carbide balls but if they really run that much cooler i will def be getting a set
#1320
Bad news. The prebuilt version of the Evader Pro ST has been discontinued. There goes RC's best value. The good news is the second best value in RC is still available for now. The Evader pro RTR.
More good news for readers of this thread. I have been reading and contributing to evader forums for the last 4 years. This is the most active thread available on the evader right now. Its contributors are knowledgeable and helpful. If you are an evader fan or thinking of getting one; this is the best place to post right now. If you are a chronic evader forum reader and want more, pm me for links to more good evader forums.
#1321
Anyone know which of the tabs on the stock photon speed motor is the positive and which the neg. I removed mine so fast I don't know which is which. I am going to use it in another project and need to know. It might not even matter on this motor. I don't know though.
Duneslider
Duneslider
#1322
NH
ORIGINAL: duneslider
Duneslider
Duneslider
#1323
ORIGINAL: philp37
Glad to see how this thread has blossomed though. And I'm proud to have started it.[8D]
#1324
I looked through a bunch of pages, but I couldn't find the answer to my question. I just wanted to know what the gear ratio of the tranny is. Sorry if this has been answered before. I want to try and get the correct final drive ratio on my Evaders. I have eight of them, four trucks and four buggies, and I seem to go through a lot of motors. Right now I'm running two P2k2's, two Revenge of the Monster's, two 13t havoks, and two Chameleon's.
#1325
NY
ORIGINAL: jubal117
man you really love them evaders dont ya, lol... do you have each one specifically set up
