The Evader Coalition ~ T.E.C.
RE: The Evader Coalition ~ T.E.C.
the evader trans is usually beefed with the al. idler and the b2 gear. are you
stripping a b2 diff or the duratrax one? what are you using to lock the diff?
if you get a steel diff gear, more than likely the case will let go.
when i locked my diff i used devcon. wich is used to repair metal. it seemed
to give the plastic gear some strength.
i wanna take a vader out but my st has a smashed rear arm, and the buggies
servo took a dump after a 50m cartwheel, and another cv. was smashed to bits.
[&o] happy days.
[&o] happy days.
VT
you could steal the uhh no you can't... that just sucks, i'm charging batts right now hopefully i'll be able to setup my sidewinder tommorow night and maybe have it good for the weekend, or be able to get my E-chaos set for the weekend tho i dunno if i'll be able to get the motor mount done in metal fab i only have like 2 hours of shop time and we gotta share tools,
the lug
the lug
MI
woot- i'm going to the hobby shop tomorrow, know lets just pray that they have what i want there [sm=lol.gif]
i might actually get to race my friends slash so i will get some vid if that happens.
also got my rc18t running today (like you people care)
i still have all funds toward my rc18t since i need a new battery pack and other misc. for it, plus my parents want me to think about getting a car soon since i will be driving next year.
VT
ORIGINAL: Matt_Gruizinga
i shall also say that i do not descrimiate against gays/lesbians, and am pound to be a vermonter seeing as gay maggiage was legalized at around 11 15 today
the lug
NC
i stripped the lower gear in my vaders tranny and might look in to doin the upgrade to it but my LHS the closest one to me dont carry Duratrax RC trucks or parts i got the gear for the XXX-T to see if it would work just have to put it together now and text it out
im not having much luck. i put all my running gear from my buggy into my st truck.
mamba 7700 combo, b2 diff. anyways, i went and paid 25 bucks for a 40 pack of
alkaline AA's for the tx. i drive out to my huge grassed area.switch everything on,nothing.
the truck wont move.starts up, does its little jingle.nothing.so i pull the motor down, clean, no dramas.
pull the esc out of its box and its lightly caked with dust and grit. i cleaned my other esc
with motor cleaner and it just seemed wrong. the mamba esc has 2 circut boards in it
with a small gap allowing junk to collect.
my question is other than compressed air does anyone know a proven cleaning method for esc's?
that doesn't harm them. (i only want to know for complex brushless esc's, not a sprint)
these esc's are practically computers. cheers.
CA
ORIGINAL: devast8r
What is the link lug I would love to go brushless.
I want to try Lipo and expect to do the upgrades, soon........I also expect to crash alot more!
CA
Here is a Nitro Evader doing laps of my Backyard grass track!
Using "Proline" Gladiators.
Cheers, Brett.
http://www.youtube.com/watch?v=hK70rrAxiKk
Cheers, Brett.
ORIGINAL: evaderholic
[&o] happy days.
[&o] happy days.
VT
or you could wait to see if you bust the case then epoxy it up nicely at the break point and maybe in other possible points, thats what i would do......... ....... more dots....... i'm really tired..... soo dots................
btw you get used to me after a few weeks...... i think........... then again i'm not used to me, and i have to live with me...... ug
the lug
the lug
I thought about trying to reinforce the case but I will have to spend money to get to that point. Thats why I might throw in the towel on the evader trans and go with something that I know I cant break..............You must be tired or bored, I am at work and both right now. Hopefully it will pick up soon.
PA
i have an xbr novak 10.5 sport system,i have the sintered upgrade rotor in it i run a max amps 7.4 ,6500mah hard case lipo , i like it.........
VT
ORIGINAL: stj7780
epoxy isn't that hard to deal with and isn't too bad for the $$$ but you gotta think, how much do you have into the evader tranny, then how much would it be to get a firestorm tranny and then what issues could come from that...
the lug
PA
when you guys are doing the b2 diff conversion are you using the factory duratrax thrust washer with the small bearings, the problem i keep having is it comes loose,instead of the thrust washer i tried a bearing ,but didnt have a flanged one,it didnt wotk, thrust bolt keeps coming loose , so i looked at the rc10t4 manual , they use 6 balls between 2 thrust washers, so i took 6 diff balls and put them between the thrust washer instead of the small thrust bearing holder, i have at least 4 lipo packs run thru it -not coming loose and not slipping .....
PA
i have the aluminum evader st idler and the b-2 stealth gear and have not stripped anything, and sometimes i rip it from foward to reverse .
