RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
The Evader Coalition ~ T.E.C.
Old 10-07-2008, 09:51 AM
  #12226
SacramentoJoe
SacramentoJoe's Avatar
Default RE: The Evader Coalition ~ T.E.C.
If the shotgun style are soldered and not spot-welded, they are usually as good as the side by side. Otherwise the side by side are usually better.
Old 10-07-2008, 04:11 PM
  #12227
rawfuls
What is spot welded btw?
Old 10-07-2008, 10:09 PM
  #12228
rclugnut10
rclugnut10's Avatar
yay a chance to show off my uber limited shop knowlage
okay a spot weld is just a weld on a small spot, so youre not welding the whole battery bar just 3 or 4 or 6 places which under 30 amps you can get away with but over that it just can't handle the power and gets hot and causes tons of resistance....
http://www.uslasercorp.com/NewFiles/spotweld-2.jpg
heres a pic now its that but smaller on a battery, so not a whole lot of contact as opposed to soldering the bar on its a lot stronger and better contacts joint...
and since i assume schooters using cheapbatterypacks.com they do have an option to upgrade which means you get it soldered for a buck more per cell, and is well worth it if you're buying quality cells (which is all they have) and since its for sub-c's + quality packs very worth it a reciver not so much but here year
dang another long rant...
the lug
Old 10-07-2008, 11:16 PM
  #12229
blazenevader
blazenevader's Avatar
heres soome pics i took today with my new body (unpainted) since it is the body for the nitro evader i had to dremel out some plastic around the rear shock tower (shown in pic 2) i also had to file down the battery tray wall to be able to get to the usb port. ( in pic 4) in pic 5 i drilled out the side of the chasis and put the esc switch there
ID:	1047983   Click image for larger version
ID:	1047984   Click image for larger version
ID:	1047985   Click image for larger version
ID:	1047986   Click image for larger version
Old 10-07-2008, 11:23 PM
  #12230
rawfuls
We didn't get it -.-
Old 10-07-2008, 11:24 PM
  #12231
blazenevader
i know my file is too larger :/ im working on it
UPDATE:: I GOT THE PICS UP
Old 10-08-2008, 12:05 AM
  #12232
FairTax4me
FairTax4me's Avatar
I would think that switch would get broken being right there. It would if it was on mine anyway. I just zip tie up the wires on mine and let the switches hang inside the truck where they can't get ripped of by a passing twig.
What motor is in that thing? I'm kinda thinking about a sidewinder, lately and wondering if I'd be disappointed.
Old 10-08-2008, 12:18 AM
  #12233
blazenevader
actually i only do high speed run on my street or indoor racing. i'm leaving my t-maxx 3.3 to do all the bashing so my esc switch should be fine. the sidewinder should be fine but since i was able to get this system for about 40$ more i thought it was worht getting the better esc. also witht he sidewinder you have to get a special cable to link it to your computer (another 20$) and the esc that i have has it built in so really it was like 20$ more
Old 10-08-2008, 12:26 AM
  #12234
rawfuls
If my eyes are right.
That looks like a Mamba Max 6,900 kV motor, right?
How are you securing the ESC down? I have it on velcro, so I can just rip it out when I need to use the USB.
Old 10-08-2008, 07:31 AM
  #12235
rclugnut10
rclugnut10's Avatar
i have the sidewinder in my evader and it's not as fast as it was in my b4 but gear raitio's are going to be played with and my top gear's been acting up ever since i got the pin, the bearing spin fine in each half of thier respective cases, but when i put it together its pretty tight when it spins... i'm gunna do some work on it tonite just to find the exact location of the problem... cuz i'm bettting the b4 isn't just that much faster (5-10 mph ) with same motor same batts and undergeared buy like 3 teeth...
so yeah i'm starting to put all my electroinics on this plastic velcro stuff thats really strong i'll see if i can find a link or get a pic later (at school) but yeah thats really nice cuz i've been changing up esc's and motors a lot...
personally i just leave my switch loose but i'm gunna tighten up the cable a bit with a zip tie but other than that it's fine loose you just gotta brign it in if you see it dragging... before i got my sidewinder i had mine mounted onto my rear tower brace...
the lug
Old 10-08-2008, 07:43 AM
  #12236
86waterpumper
I have noticed too, that for some reason the evader doesn't go as fast with the same motor as my other cars do. I don't know if the transmission is just not efficient or it's just the overall size and weight of it, or what the issue is, maybe I need to change out all the bushings for bearings, but that can't account for all of it. I have noticed that if I crank down hard on my wheel nuts, it seems to sort of bind everything up, so I have to end up backing off maybe 1/2 a turn.
Old 10-08-2008, 12:04 PM
  #12237
FairTax4me
FairTax4me's Avatar
Lug, I bet one of the bearings is seated crooked. I had the same thing happen on my rustlers diff bearings and one of them just hadn't been pressed in all the way flat.
I noticed a HUGE difference in my rustler when I finally went all BBs. Don't know if it really makes that big of a difference or if my bushings were just completely shot, but it was like night and day.
Old 10-08-2008, 01:25 PM
  #12238
rclugnut10
rclugnut10's Avatar
thanks thats probally it, i was messin' with um, ie. sliding them along the shaft to try to get um off for kicks... so thats more than likely it, i'll see i can get um happy or i'll just get some new ones cuz i'm ordering a new spur and a few other odds and ends at somepoint this week...
the lug
Old 10-08-2008, 09:03 PM
  #12239
blazenevader
ORIGINAL: rawfuls
nope it's the 5700kv. it can actually go faster than the 6900 bc you can use a 3s lipo. so far from what i know the 6900 and 7700kv only allow a max of 2s lipo.
also my esc is held in place by double sided stickey foam tape stuff. i need to get velcro though. my esc came loose while driving today.
Old 10-08-2008, 09:06 PM
  #12240
rclugnut10
rclugnut10's Avatar
that sucks when that happened i ended up dragging mine for a bit when that first happened....
the lug
Old 10-08-2008, 09:22 PM
  #12241
rawfuls
Ouch.
That sounds not too great.
Shows how much I know -.-
It looks like a 6900 to me. -.- Eh
Old 10-08-2008, 09:28 PM
  #12242
rclugnut10
rclugnut10's Avatar
it lived... and my evaders also been covered in a 1/4 inch of the white fluffy stuff (snow, not the "happy white fluffy stuff") and lots of other things, mud, dirty water that came with the mud, and probally a few other things that void the warenty...
the lug
Old 10-08-2008, 09:33 PM
  #12243
rawfuls
You..disturbing minded kid!
Sheesh, I don't bash in those conditions. Sunny, NICE days is when I take it out. Otherwise, I take it to the computer
Old 10-08-2008, 09:40 PM
  #12244
rclugnut10
rclugnut10's Avatar
bah, i only don't drive if it's raining remotes are expensive, but let me tell you, wear some gloves if you decide to drive when it's 4 read it 4 degresse out, cuz your hands get cold FAST, on the plus you don't have to worry about your esc over heating, and mud never hurt nothin' just gotta clean it after [&:] but then you can find all the stuff you broke so that means new stuff,
i was a little muddy at the track...
the lug
Old 10-08-2008, 10:08 PM
  #12245
rawfuls
Man, how I wanna do that so bad.
I hate breaking things down and cleaning em.
Old 10-08-2008, 10:16 PM
  #12246
rclugnut10
rclugnut10's Avatar
LOL get some canned air, or a air compresser, or just by a spray head for a compresser go down to the gas station, and go to town... but yeah i just got a air compresor so i can't wait to get um dirty again, cuz i probally spent a good 5 hours cleaning that, i lost tools in the piles of dirt... but it was a good day at the track, i drove good it was running good,
the lug
Old 10-08-2008, 10:22 PM
  #12247
rawfuls
Oh I have like a 10 year old air compressor, that's still insanely working great!
Old 10-08-2008, 11:56 PM
  #12248
heta peta
ORIGINAL: rclugnut10
the lug
That is my driving season to a T! the colder and harder the ground, the better.
Old 10-09-2008, 09:56 AM
  #12249
cheech4
cheech4's Avatar
ORIGINAL: rawfuls
Ouch.
the 6900 is a beast, i love mine... especially on 2s lipo... i heard the the new castle 6900 can run 3s.
Old 10-09-2008, 03:18 PM
  #12250
rclugnut10
rclugnut10's Avatar
ORIGINAL: rawfuls
then why are you so afaid of mud???
the lug
