If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 492 of 825 FirstFirst ... 392442482490491492493494502542592 ... LastLast
Results 12,276 to 12,300 of 20624
  1. #12276
    Join Date
    Aug 2008
    charleston, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: The Evader Coalition ~ T.E.C.
    I'm no expert. Guys on here know way more than me, but I'd bet the 17T has too much torque. I'm shocked your stock esc hasn't burned out...it shouldn't handle any more than 19t
    Evader EXT
    Losi xxx-t
  2. #12277
    BEARBYSR's Avatar
    Join Date
    Jan 2007
    WARMINSTER, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How do you get the Previous Post to show up in the reply?
    Just copy and paste it to the reply box, then highlite it and hit the quote button(little blue one above the reply box) that should do it, hope that helps.
    O.S. POWERED DTX NITRO EVADER/ DTX RAZE/MGT/EVADER EVST
  3. #12278
    Join Date
    May 2008
    Woodland Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Or, you could just click "Quote" on the top right.
    Yes, your ESC should have, if not burned out already.
    A good reminder, is to slide a piece of A4 paper in the mesh, and make sure it's as tight as it can be, but with the paper still in there, not ripped.
    This is a good thing to go by.
  4. #12279
    rclugnut10's Avatar
    Join Date
    Apr 2008
    Hinsburg , VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: esky77
    will a associated b4 tranny fit
    uhh, i've been meaning to test that for a while now cuz i happen to have a B4 and have been meaning to test that very theory out, i've looked at the mounting holes and i don't think it's possible with out some fabirication but i haven't accually compaired the two next to each other
    for gear mesh i just eyeball it, i look to have just a wee bit of play but the gears should also be smooth
    the lug
    Savage Flux 2350 Evader ST Pro EXT \'\'Detta ST E Choas, HPI E Firestrom Novus CP
  5. #12280
    Join Date
    Aug 2005
    Liverpool, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So...I ended up with the ICE after all. I really compared the specs of this to the TC charger and I really couldn't find where the extra 50 dollars would get me that far.
    Nonetheless, as far as gear mesh goes, you want to be able to take a piece of paper and run it through the two gears, while leaving marks, but not ripping the paper. This should be tight enough not to burn up your spur, but loose enough as well. I have had my evader for many years at this point, and while I took a year off, I still have used it quite a bit. Further more, I have a 10X2 Team Checkpoint motor in there. There is no way that a 17t motor is burning that spur up, while it might kill your ESC, I'm still running my stock spur gear, so if it was installed correctly, I'd have to say they wouldn't be melting on ya.
    FairTax4me,
    These are all the stock numbers on tower for everything you need to remake the diff and tranny on the evader. This works great, so if you're looking for a stronger set to handle your brushless system or just plain to make it better, here you go.
    LX3224
    LXFZP0
    LX3225
    LXD109
    LXCPH0
    LXCPH1
    LXAV73
    LXGS07
    Well, hope you come back to the hobby soon cheech, I hope everything works out for you. Ah well, I was wondering if Raz was still making those braces, but I guess if he hasn't been around, we'll just have to see if he shows up again.
    -Ziggy
    Rides: Evader ST, Evader BX, Savage 25, XXX-NT, Mini-T, Micro-T, RS2 Pro, Slash 4x4
    Wishlist: Savage Flux, Hellfire
  6. #12281
    rclugnut10's Avatar
    Join Date
    Apr 2008
    Hinsburg , VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    b2 diff conversion well worth it i got it and love it i got the links poser in the mid 470's i think, i got um to go from ext to evader tranny with b2 and just go to b2 i belive but i'm not sure exatcally what it entails, but take a looksie
    the lug
  7. #12282
    riverat1540's Avatar
    Join Date
    Mar 2006
    Algonquin, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hey everyone long time no see. ive been busy with work trying to score a buck or 2 to get another battery after my last fatal accident that toasted my lipo. i did have the fastest evader until i hit the curb at 45 mph if u search brushless evader ull see my truck its the real fast one running at night. well hope to see u on some time cheech and my babys ready to go just needs another sweet lipo. and if anyone needs to know anything i can probally help as ive pretty much done it all to my evader st. so take care yall ill try to stop in more often
    Think Big, Then Go Bigger!
    Duratrax Evader ST Pro, Blade Cp, CEN GTX 7.7
  8. #12283
    Join Date
    Aug 2008
    charleston, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Ziggmiester
    FairTax4me,
    LX3224
    LXFZP0
    LX3225
    LXD109
    LXCPH0
    LXCPH1
    LXAV73
    LXGS07
    -Ziggy
    Doesn't this come in a kit at a discount?
    What about the b2 conversion that is also talked about above....is that another option or the same one.
    Evader EXT
    Losi xxx-t
  9. #12284
    Join Date
    Aug 2008
    charleston, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When I do my Tamiya to Deans conversion later this week, I assume you also have to change the connector on the battery charger, correct? So I'll need deans plugs for battery charger, esc, and batteries. Any dangers at all with the battery, since there is no way to prevent the battery from still having a charge while we're doing it?
    Evader EXT
    Losi xxx-t
  10. #12285
    Join Date
    May 2008
    Woodland Hills, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Don't cut both wires at the same time.
    Make sure your Deans and wires at on the same polarity terminal.
    Hmm, well, yes, you can keep your Tamiya on your charger, but you could make an adapter, but what would the point be to replace the connectors...
    Yes, it's called the DTX Diff rebuild it, if that's what you're talking about.
  11. #12286
    rclugnut10's Avatar
    Join Date
    Apr 2008
    Hinsburg , VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rawfuls
    well yeah that's about it with the batts, don't cut both wires cuz you'll short the pack make a big spark and fry you're batts in about half a sec and then flip out .25th of a second later so yeah cut 1 at a time
    also i'ld put the deans on the zapper just cuz you'll get a better read on weather its full or not and probally cut charge times by a bit...
    the b2 is listed there
    the lug
  12. #12287
    FairTax4me's Avatar
    Join Date
    Feb 2008
    Charlottesville, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just went down to my LHS and they had a Duratrax rebuild kit so I said scrooge it, and just did that with the Carbide diff balls. I got it back together but something is either screwy with the motor, or I'm way overgeared even on a 16t pinion because it cogs like crazy and it gets hot as the devil after trying to drive just 50 feet. Gonna swap the worn out Titan from my slash and see how it acts with that. If its better then Ill know I did something wrong when I put the 9T back together.
    *Compact battery box is waterproof against dust!
    Rustler, Slash, TA03F, 4Tec, Evader, X-Crawler, Cx3 heli, more?...
  13. #12288
    BEARBYSR's Avatar
    Join Date
    Jan 2007
    WARMINSTER, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey riverat1540, that is still one of my all time favorite evader videos, I show that one to all my nitro buddies when they start up the old " nitro is faster then electric smack" they just get the [X(] look
  14. #12289
    rclugnut10's Avatar
    Join Date
    Apr 2008
    Hinsburg , VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: FairTax4me
    the duratrax rebuild kit is usefull if you're doing the b2 upgrade cuz you get new stuff, but if you're getting carbide balls it's useless, you're diff could be too loose you could have somthing jamming it, or screwing somthing up that happened in the rebuild, so i'ld take off the tranny and just spin the spur to see if everything supersmooth
    the lug
  15. #12290
    Stang444's Avatar
    Join Date
    Jun 2008
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think Ive heard rumors, but are duratrax evader parts close to compatible w. the losi xxx-nt parts? its an electric convertion and the front end just gets worse and worse gradualy.....so I want aluminum.
    [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAZN1&P=SM[/link]
    [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAXP3&P=SM[/link]
  16. #12291
    rclugnut10's Avatar
    Join Date
    Apr 2008
    Hinsburg , VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Stang444
    those parts are for the overdrive ST and don't look they'll fit at all
    http://www3.towerhobbies.com/cgi-bin...?&I=LXBVG1&P=Z
    an aluminum bulkhead
    http://www3.towerhobbies.com/cgi-bin...?&I=LXBDK0&P=Z
    steering hubs
    knuckle arms
    http://www3.towerhobbies.com/cgi-bin...?&I=LXBDK4&P=Z
    rear arms that may or may not fit i'm not sure...
    http://www3.towerhobbies.com/cgi-bin...?&I=LXGGU2&P=Z
    that's all the evader aluminum
    http://www.duratrax.com/caraccys/dtxc6182.html
    that's all duratrax's hop up's idk if they make aluminum arms for the evader or if any of that stuff will fit, but i have heard speak of duratrax stuff fiting with losi, i know that the rims are compatable.
    the lug
  17. #12292
    FairTax4me's Avatar
    Join Date
    Feb 2008
    Charlottesville, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Transmission turns smooth as butter. The grease is still a little sticky but it all turns freely.
    And the diff I tightened the way Duratrax recommends. All the way down then back off 1/8th turn. The truck has plenty of speed once its going but on the bottom end it just wont do anything.
  18. #12293
    rclugnut10's Avatar
    Join Date
    Apr 2008
    Hinsburg , VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    what motor, that could be the problems and do you have tam connectors? they could be causeing problems, and check your brushes they may be shot....
    the lug
  19. #12294
    Join Date
    May 2006
    Comerio, PUERTO RICO (USA)
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi, I are very fan of this car. I have mine about 3 year. I have a Evader pro. I like this car a lot, I flip flap this car, crash it a lot of time and only broke the front tower. You can imagine Im selling my Revo 3.3 barely new because I going to use that money to upgrade my evader and for other hobbies. Actually it have the novak brushless 5.5R sistem, I bough a 4200 duratraxbatt. The problem is that this setupis very powerful and broke the diff a lot of time (runs like 45 mph in only 3 or 4 seconds, still not reach the max mph), im tired of changing the diff. I wat the evader ext conversion. If anyone alredy do that please thell me whatparst I need to buy. I also want the name of a smetal spur gear. I want all the tranny in metal to handle the great acceleraion. I also need a wheelie bar.
  20. #12295
    Join Date
    May 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I will put images when the evader are finished
  21. #12296
    rclugnut10's Avatar
    Join Date
    Apr 2008
    Hinsburg , VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Evader-Revo master
    lol you sould just like me mid august lol
    you'll want the b2 convesion for the better tranny you can't get all metal gears but 2 of the 3 internals and one really durable one
    to find the conversion check out cheech4's sig i belive he has a post on this page but it may be 1 page back
    edit look down lol cheech you always seem to post a comment right after i referacne you
    the lug
  22. #12297
    cheech4's Avatar
    Join Date
    Feb 2006
    astoria, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    here ya go, lol
    Traxxas Mini E- Revo VXL, Mamba Evader ST Pro.
  23. #12298
    Join Date
    May 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the b2 conversion is more strong that the evader ext? and what metal spur gear will fit?
  24. #12299
    Join Date
    May 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok, I was reading post, and says that the B2diff is more strong that the ext diff. What parts I need to buy? The carbide balls is a lot stronger? It can handle the 5.5 powerful aceleration? I mean I want to drag racing a little with my friends and start with 100% trotle, do wheelies. I dont use the car for jumping. I use the car on street and in the park. Maybe a little off-road. The diff was broken in the street when I bought the 4200 mAh batt. A greatr acceleration start breaking my diff, you know the sound of the diff balls. I try t tighten my diff but the sound persist and the turns gets bigger. Finally the motor of the car runs but the car dont move, the diff is very tigh but I think that the balls get worned and smaller. If the B2 convertion can handle that more that the ext tranny i will go with the b2 tranny. I dont know how to adjust the slipper clutch so it is very tight all the time.
  25. #12300
    Stang444's Avatar
    Join Date
    Jun 2008
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rclugnut10
    ORIGINAL: Stang444
    steering hubs
    knuckle arms
    the lug
    Thanx rclugnut
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
