The Evader Coalition ~ T.E.C.
#1351
RE: The Evader Coalition - T.E.C.
There has been a myth perpetuated on forums and by some hobby shop personell ever since the Evader came out. The myth that an evader st is a basically a losi xxt. (The same being said about the buggy versions) That Duratrax bought the molds from losi and made some minor mods. Easy to believe at first glance because they look similar
They are not made from the same moulds. There are a few parts that will fit both.
molded parts of similar size that fit with little or no alteration:
front bumper, xxt
a-arms, xxt-cr, xxxt (xxt arms will fit, but will narrow tread width)
Rims – all losi 1/10 stadium trucks. (xxxt -2 take different hubs)
F& R shock towers xxt, xxxt. (One takes some mod of the rear tower)
Moulded parts not fitting Evader from any Losi:
Chassis (looks similar but at front are very different)
Servo Brace
Front Brace
Rear Transmission Brace
Toe In - Anti Squat knuckle
Battery Strap
Front Bulkhead
Rear Chassis Plate
Motor Guard
Bell Crank Set
Steering Servo Set
Steering Servo Mount
Even the moulded parts that do fit are NOT from the same mould.
These lists are very near complete. I am not sure about hubs, carriers, and front body mount.
The transmission design is very different from Losi as is most of the slipper. The Evader Trans does resemble an AE stealth trans and some AE parts do fit it.
The evader will take rims that fit AE and Losi, but the losi ones are the ones with the correct goemetry. Losi length rods from the xxxt also fit.
Many other manufacturers shocks will fit, including losi, AE, sportwerks Raven
The turnbuckles of xxt-cr and xxxt will fit. The xxt are two short unless xxt a-arms were used. The hinge pins are all different in both length and design.
I have not finished researching the xxxt-2. however, longer arms is the main theme, so many of the same parts compatibilities or lack there of should be true.
Please advise me of any errors or omissions on my list.
front bumper, xxt
Servo Brace
Front Brace
Battery Strap
Front Bulkhead
Rear Chassis Plate
Motor Guard
Bell Crank Set
Steering Servo Set
#1352
I am in the process of rebuilding my transmissions in all my Evaders. I was wondering if you should put any lube on the idler and diff gear. I have heard from some people that you leave them dry, and from others that you use grease. I figured before I put them back together, that I would get some advice from these forums. Sorry if this has already been asked, but I didn't see the answer I needed in the previous pages. Thanks in advance for your advice.
#1353
CA
If you are going to all the trouble of rebuilding your tranys you should upgrade to the aluminum idler gear too. If you do then you have to grease both metal gears teeth.
#1354
In addition to what Raz said, use grease even if you just use plastic. In moving parts like that grease will help. It might not be needed but it will help. As to how much to use, I don't think you need a lot but some put in as much as they can fit. I like enough to just coat everything.
duneslider
duneslider
#1355
NY
ORIGINAL: duneslider
duneslider
duneslider
what kind of grease is recomended?????
#1356
CA
Does any one have an idea why my motor would be cutting out? It doesn't do it when I'm close to it but when I am about 25 feet or farther away the motor cuts out, forward and reverse. All the wires from the esc to the motor are factory soldered and I have Deans connectors on the battery. It just recently started and it's getting worse. The steering still works so it's only the motor and the truck doesn't stop, it just cuts out till it's close to me again. I even tried replacing the antenna wire in case it was broke but no change. Forgot to mention it is the novak SS4300 esc / motor
#1358
CA
How would I test the rx to see if that's what's doing it? I never have taken the motor apart yet to clean it, could that cause it?
#1359
ORIGINAL: cheech4
duneslider
duneslider
this is what i reccomend for the dif gear
http://www2.towerhobbies.com/cgi-bin...91&FVPROFIL=++
dont get it anywhere els other than the diff (make shure to wash ur hands after using before installing any thing els also on the gears themselfs i use regular white automotive motor assembley grease it works awsome and on the bottle i have now it even says for use on rc cars to
#1360
My Feedback: (34)
Not sure how to test it, but it most likely is NOT the motor being dirty.
Also, a little advice...NEVER run a reedy quad mag in water. I ran it on a drizzle-slicked road and it's wruined. The torque now sucks and the speed is slightly lowers. So, now my evader is trash to me. The tranny is dead, the motor and esc are done, the rim is cracked, etc. Anyone interested pm me.
The worst part is i can't use anything off of it. The wheels don't use hexes and the shocks are too long for my other cars.
#1362
You can locktite them in or put shrink tube over the joint. Both work. Or upgrade to the CVD's and not have to worry about it.
Duneslider
Duneslider
What's shrink tube?
#1363
this is shrink tube
http://www2.towerhobbies.com/cgi-bin...nk&FVPROFIL=++
dracohowe ur gonna get in trouble if u keep tryin to sell that thing here put it in the sales section here
#1364
CA
ORIGINAL: ThatsAnEvader!
How would a little drizzle hurt the motor? I have ran them totally submergerd and never hurt them. I could see damaging the esc though if it got wet. That's too bad about your vader.
#1365
NH
ORIGINAL: raz54
#1366
My Feedback: (34)
ORIGINAL: raz54
#1368
CA
I just tried had my truck on the stand turned on and started walking out side holding the throttle down just a little and about 25' away it started speeding up then slowing down. If it was the motor though wouldn't it be doing it all the time and not just as it gets farther away?
#1369
NY
ORIGINAL: discgolfer72
ORIGINAL: cheech4
duneslider
duneslider
ok so associated diff lube for the diff, and white greese for the rest if the tranny. got it thanks
#1370
CA
The white grease (or clear) goes in the diff and the black grease on the gears.
I just put all my old stuff back on (motor / esc) and at first it was working good then it started cutting out again and the more I ran it the worse it was getting. At least I know it's not my new bl motor but does that sound like a rx or possibly a xtal?
#1371
NH
ORIGINAL: raz54
#1373
[quote]ORIGINAL: raz54
i told him to use automotive white motor asslembly grease to lube the actual gears
that what he means by white grease /it works awsome its what i use on all my cars it even says for use on rc trans gears on the bottle i have now
its a heck of a lot cheaper than using the ass black gear lube think i paid 3 bucks for my bottle and its huge
now i just need to find somthing thats cheapand works as good as the diff luube
#1374
NH
ORIGINAL: raz54
I can borrow another radio (complete) but that won't tell me if it's the rx, tx or xtals, mine is 75 and the other is 27.
#1375
CA
ORIGINAL: Crash7772
Could rule out the motor/esc 100% though.
ORIGINAL: raz54
I put on all my old stuff (motor,esc) and it still does it. Then I took the rx out of my boat and put it in and had to use the boat tx as well and it still does it. The more I run it the more it acts kike gicthing. The only thing different is the aluminum front end, could that be causeing this? It even does it at the hit of the throttle so the truck is barely moving (less than 1 mph). It has to be something in the truck since I replaced everything else.
