The Evader Coalition ~ T.E.C.
VT
RE: The Evader Coalition - T.E.C.
ORIGINAL: glancyguy
Thanks for your post. I do not own a Traxxas (how dare I!) and was getting it confused with their brushless editions...
A different topic:
The stock BX has quite a bit of oversteer for my driving tastes, especially with a 19T motor in it. I have heard many conflicting reports about how best to treat the diff. Can I tune the diff on these cars (like I can with tamiyas) to adjust the oversteer? Or should I just leave the diff EXACTLY as mentioned in the manual?
A different topic:
yeah i've always seem to justify buying non traxxas cars tho i probally would've ended up with a t-maxx or revo if i hadn't found my savage for the what it costs now, tho when i got it it was like 80 more... also i was gunna go with a rusty (gen 1) but got the evader pro for the $$ it was a way better deal 12t esc, digi radio, faster motor, better parts Al shocks...
the lug
you can loosen the diff very slightly but make sure
the slipper is slipping before the diff and your good to
go. i run brushless and have it tight as hell and it ruined
the thrust disc making it hard/notchy. i replaced it with 7
diff balls, and even super tight the diff is smooth as.
have you looked inside the diff?
i wouldnt lock a diff. only good for burnouts really and
crawling.
crawling.
CA
Hey lug, my ST came with a 20 tooth pinion, not the 18 that it says. I run an 18 now with the Dirt Hawgs and the 4600.
For the oversteer, you can try to set your shocks and suspension different. I'll try to find some info. If I remember right, moving the bottom of the rear shocks to the inside will soften it up and that might help on the slippery tracks.
VT
yeah it is, tho i may get some outdrives and make a locked one just for fun cuz i think my diff loosened and thats why something gave out last weekend, i'm gunna start using locktite more.....
yeah def about the slipper tho i had loosened mine 2 bashes before my diff gave out, and loosened it more the bash before.....
the lug
the lug
VT
ORIGINAL: SacramentoJoe
the lug
OK
ORIGINAL: robosnow
the gear that came off the titan 12t has 18 teeth. I have run a fully charged 7.2 3100 just now and man this thing pulls decent. I can pull wheelies 3-4 feet long (going out of reverse to full on forward with the stock duratrax gear.) Sooo will it pull harder and have moretop end if I go smaller on the gear thats on the motor?
Chris
Chris
I am not really an expert at this, but it is what I have learned over the months and doing lots of research. Here is adecent explanationof it.
VT
[quote]ORIGINAL: glancyguy
ORIGINAL: robosnow
the gear that came off the titan 12t has 18 teeth. I have run a fully charged 7.2 3100 just now and man this thing pulls decent. I can pull wheelies 3-4 feet long (going out of reverse to full on forward with the stock duratrax gear.) Sooo will it pull harder and have more top end if I go smaller on the gear thats on the motor?
Chris
Smaller pinions (and spur gears) reduce the effort it takes for the motor to spin the gears. Lower turn motors have less torque than higher turn motors. This means they have to work harder to spin the gears. Less teeth requires less torque and therefore lets the motor spin more free. This allows it to spin at its max RPMs (top line speed) without much pressure on the motor. Cars that don't have the right pinion/spur for the motor are called
Chris
however if you can get the same FDR with smaller gears it will help your power because it reduces rotating mass (more so on cars with bigger spurs/metal ones), and rotation mass eats power....
the lug
CA
I've experimented with the Robison Racing Pinion set (Odd # pinions 15 to 25t). I'm running Komodo 19T Pro's - Road Hawgs to Yokohama's (large Dia) tires, 88t stock Spur and a big 96t spur. found that anything between 19 and 23 works for good torque, good top speeds and general acceleration without over heating the ESC or motor. The low and high end pinions tend to cause problems. Been having issues with Battery heats that I think are more related to bad cells rather than gearing.
The Robinson Racing machined 96T spur gear with a 19t pinion is good times - might have to shave a bit of the motor mount to get spur and pinion to fit at correct mesh. Running a good Komodo 19T Pro with XL-5 and some larger spike tires (not quite as large as the Yokohama's but big). On my EXT at the moment - and runs very fast and strong torque even on those junky 6 cell NIMH.
IMO - experiment between 19t and 23t and stick to what matches your driving style/wheel diam/road surfaces and doesn't fry the works.
PA
How are ya cheech? You missed some awful evader trash talk but thankfully the thread whatchers deleted the posts. As we all know, we are all here to help each other and to have fun, not ridicule. Have you had a chance to run your mamba vader lately?
OK
ORIGINAL: sam rojas
IMO - experiment between 19t and 23t and stick to what matches your driving style/wheel diam/road surfaces and doesn't fry the work.
ORIGINAL: monsterbombs
first thing i would do is pull down the tranny/diff and
relube everything and check its condition. other than that,
checking the motor for comm/brush wear and making
sure the shocks all have oil. thats about all i do, i also
glance over screws and spinning things for binding/worn
bearings.
bearings.
Thanks for your reply Monsterbombs
hrd
CA
Hey Dave, the TEC has been missing you! There is still alot of good conversations here. Been a few bad ones also. Anyway, I have been running my ST on the CC SW 4600 and some 2s LiPos. I even have quite a few runs on a 3s LiPo now and I am still running the stock diff and tranny. A year and half ago, I was asking about the CO27 motors, but now thanks to the TEC, I am feeling experienced.
I had a rough day yesterday. My rear chassis plate actually wore so thin from jumping at our track (for 1-1/2 years) that it cracked at the motor guard holes. The very back of it looked like a knife edge. Then on the way back to the house, I dropped my radio and snapped my antenna. Some days are great, some days not so good.
CA
ORIGINAL: hrd2fnd
Hate to ask, but what type of lube should Ipurchase and also what should Iget to keep this in good condiction after each use?
hrd
hrd
lube the the diff balls with good silicon based lube, and for the gears i would use ceramic black grease
As recommended by Cheech on page 381:
ORIGINAL: hrd2fnd
hrd
hrd
Thank you
RI
If any of you evader guys are interested i am going to be stripping apart my st pro and selling off all the graphite parts in a package deal now this will just be the graphite parts no electronics. I will have a picture up a bit thought i would offer it up here first.
CA
With still be new to this sport and this forum, I havent made it through all 584 pages, but am working on it and will be taking notes along the way. So I ask that everyone please bare with me if I happen to ask a question that has already been anwered over the years on previos pages.
Thank you
Thank you
No problem, now if only I can figure out how to keep the motor from eating these dang little screws on the cover when I take it off. Just spen the last 1/2 hour fishing it out of the motor.
NY
ORIGINAL: BEARBYSR
oh geez you mean i missed a good fight, i would of layed it DOWN... lol. no one talks trash about the vader when im around. the silvader is doing AWSOME got me some 2S lipos and run wild with it. its crazy fast. i will make a vid next time i get me a cam. mine broke and them things are expensive. but all and all, all is good.
NY
PA
CA
Yes, lots of posts. People can't seem to stay away from this thread.
I can't seem to get my videos uploaded. They won't work off of my Google Group site after I editted them. Guess I have to join YouTube.
RI
Here are the pictures of the graphite pieces the front shock tower has a piece broken off at the bolt but it still holds tight on the other three and even the broken one still holds tight. No electronics haven't figure out if i will be getting rid of them yet and the hardware pieces i am still sorting out but for the most part will be in with the parts when it sells.
I'm asking $40
I'm asking $40
