RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
The Evader Coalition ~ T.E.C.
Reply
Old 04-19-2006, 12:05 PM
  #1376
discgolfer72
discgolfer72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: The Evader Coalition - T.E.C.
raz have u tried a diffrent motor ur caps in the motor might be fried causing glitching
discgolfer72 is offline
Old 04-19-2006, 12:14 PM
  #1377
raz54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: discgolfer72
I'm running a bl motor so there are no caps but as I said above I tried my old motor and esc and even a whole different rx and tx and stii it does it. The only thing I can think of that's different now is all the alum front end pieces. I gave all the graphite to my nehew so I can't put it back on. Do you think an FM radio would work better?
raz54 is offline
Old 04-19-2006, 12:29 PM
  #1378
CustomTamiyas4Life
My Feedback: (34)
CustomTamiyas4Life's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds exactly like what happened to mine when i installed aluminum.
Raz, try running with a reciever pack. This greatly decreased glitcing and increased range for mine when it was acting up.
CustomTamiyas4Life is offline
  #1379
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ah
well ive heard here that fm is better for brushless (less glitching ) but im not +
Old 04-19-2006, 01:46 PM
  #1380
raz54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just talked to a tech. at futaba and he suggested an FM too. He said he didn't know if it would cure the problem but when running a bl motor he said I should upgrade to FM anyway for better control. So it looks like an FM radio is next. For now I'm going to try it with the old bulkhead and see if that helps at all being less metal to metal.
raz54 is offline
Old 04-19-2006, 02:12 PM
  #1381
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well let me know when u get the fm if it fixes the problem then i can be 100% shure fm is a fix for brushless glitching
also just got back frm the lhs i bought a associated b2 dif gear it looks like it will fit but ill let u all know if it does (its about 1.00 cheaper than the stock duratrax part )
Old 04-19-2006, 02:36 PM
  #1382
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well its installed and looks like its going to work really good (theeth match up perfect) only problem i had was the evader dif bearing was to big so i had to dremmel out the hole(u could prob just get a new bearing) in the associated diff gear (luckley i had a bit that was the perfect size )it was a little tough(big chance of not centering the hole but its looking good and dosent seem to be out of round (it turns smoothley )
here r some pics
ID:	447878   Click image for larger version
Old 04-19-2006, 03:35 PM
  #1383
CustomTamiyas4Life
My Feedback: (34)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For some reason my tranny was never smooth...even after loads of grease and cleaning.
Old 04-19-2006, 03:59 PM
  #1384
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well the b2 diff gear is sounding smother than the orignal gear so far havent ran yet
(i only reccomend using one if u have a steady hand/to make the bearing hole larger //unless u can find a bearing that will fit bolth the evader and the associated diff gear) but after installing the tranny in my vader and turning the tires it seems super smooth and the b2 diff gear looks to be a loot better nylon and is 1.00 cheaper
Old 04-19-2006, 04:31 PM
  #1385
duneslider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is a different bearig that works, I believe the ones you have are 5x8 and you need a 5x10. I think that is right. Or you can just dremel it out like you did. Both methods work. So next time you can try the bearing. Also, I hear the associated diff rings are a little better. I think they are just a little thicker and last longer. The nylon is better that associated uses. You should look into replacing the idler with the metal one too. You will have to let us know how this one holds up. I have only heard one person say they have done the plastic b2 gear. He said it lasted longer than the duratrax one.
Nice to know it was a pretty easy install.
Duneslider
duneslider is offline
Old 04-19-2006, 04:36 PM
  #1386
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea it was easy took about 2 min with the tranny already out (that includes dremmeling and reinstalling into the car)the part that took the longest was digging the stock diff balls out of the melted stock dif gear
i think the associated diff rings are a little bigger it seems like the stock diff rings only cover half of the diff balls but it seems to slip ok with a loose diff setting but im tightening mine pretty tight now since im running my low turn motors and am looking for speed not controll
also u got a link or asc part # for the other gear
Old 04-19-2006, 04:40 PM
  #1387
cheech4
cheech4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: duneslider
Duneslider
i just bought 2 nylon b2 diff gears, and rebuilding the tranny i will let you guys know how mine runs...
cheech4 is offline
Old 04-19-2006, 04:47 PM
  #1388
duneslider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFZP0&P=ML]Alum Idler Gear[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LX3225&P=7]B2 diff rings[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD109&P=ML]Bearings for B2[/link]
Here are some links for what you need and may want.
Duneslider
Old 04-19-2006, 04:51 PM
  #1389
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
did u get the diffrent bearings
Old 04-19-2006, 05:04 PM
  #1390
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
man duratrax is proud of their junk ! 16$ for that little gear
i liked the b2 diff gear since its cheaper then their part
someone els has to have a cheaper metal one to
what about the associated one ive heard people talk about in here
Old 04-19-2006, 05:11 PM
  #1391
duneslider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is for an aluminum idler gear. Sixteen isn't that bad. There is no other one that will work. If you go and look, you won't find any metal gears that are much cheaper than 16 bucks. There is a metal b2 diff gear but they are almost impossible to find. In fact, I had someone offer me $50 for my metal diff gear. That is how scarce they are.
It takes a lot of work to machine those gears, they will cost more than the plastic parts. If you buy that alum idler gear you will never have to replace it again. It will pay for itself pretty quick.
Duneslider
Old 04-19-2006, 05:21 PM
  #1392
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lol yea but still 16 bucks my robinson alum hardened pinion has more material and was only 3 bucks
but yea yr right just had to complain on rc prices
Old 04-19-2006, 05:25 PM
  #1393
duneslider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will agree it is a little high.
Duneslider
Old 04-19-2006, 05:44 PM
  #1394
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lol yea
well for the virgin run the b2 diff gear is going really nice it quieter than the stock ever was(might have to do with my automotive grease tho lol) and runs great
I'm using my vintage 15 t Trinity speed works motor now tho wanted to break it in a bit before it gets full 9 t power
ill get some vid s tommorow
Old 04-19-2006, 06:00 PM
  #1395
cheech4
cheech4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
why do you need a 5/8 bearing on the b2 diff gear i thought they were the same... isnt the stock diff bearing in the evader tranny a 5/10.... and also this might sound silly but i havent opened the tranny yet but where would the bearing be located
cheech4 is offline
Old 04-19-2006, 06:03 PM
  #1396
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its in the center of the diff gear and the stock evader diff bearing will not fit the b2 diff gear i used a dremmel tool to modify my b2 gear but its tricky business
if u dont do it right the gear will not turn true and u defeat the purpose of replacing the gear
everything els is the same outside diameter and number and size of diff balls
Old 04-19-2006, 06:09 PM
  #1397
duneslider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: cheech4
I think the inner bearings are 5x9. So you have to dremel out a tinny bit if you run the stock 5x9 bearings. The outer diff bearings are 5x10.
Duneslider
Old 04-19-2006, 06:23 PM
  #1398
cheech4
cheech4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: cheech4
Duneslider
the reason i ask was i just got off with tower trying to change my order cuz i just bought a bunch of stuff for the diff and tranny, but got the wrong bearing for the b2 gear, but to late im stuck with the 5*10 bearing ... but all is well i ordered the 5*8 bearing and they waived off the shipping costs,,,, got to love tower hobbies
cheech4 is offline
Old 04-19-2006, 07:08 PM
  #1399
cheech4
cheech4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
got a new body for my evader, i have to modify it justa tad the rear shock tower are in the way, so a little dremmelin . so here is the semi finished product.[link]http://i59.photobucket.com/albums/g301/cheech4/Picture.jpg[/link]
cheech4 is offline
Old 04-19-2006, 07:32 PM
  #1400
discgolfer72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks awsome
i like my elcaminevader better tho lol
just another shamless elcamevader plug but hopefully now tht the tranny is beefed up you will be seing some good elcaminevader vids soon
ID:	448034   Click image for larger version
Contact Us Archive Advertising Cookie Policy
