brushless for Losi XXX-T bashing
I have a Losi xxx-t stadium truck ready-to-run. My stock Novak esc keeps shutting down due to thermal overload. Its mostly just bashing on grass, but that's where I need to run. I've already tried 15-20 tooth pinion gears, but it still shuts down when I run too hard. I would like to upgrade to brushless to hopefully prevent overloading and wanted a recommendation. I'm thinking of either the Sphere Neo 2 star or the Novak GTB 6.5 Anyone have good/bad experiences with these in the XXX-T with the stock XR2 radio/receiver? Even though it's an "off-road" truck, I'm mostly running on the road and in low-cut grass. I know the Sphere handles 7-cell, and is a little smaller, but the Novak is less expensive. Again, for me, thermal overloading seems to be my biggest concern. Thanks in advance for your experiences.
RE: brushless for Losi XXX-T bashing
A brushless system will still thermal if pushed to the point of overheating. Use a fan over your ESC and a heatsink on your motor. Gearing is also important in addition to the fan and heatsink.
I don't see where I can mount a heatsink to the motor. The back frame of the truck is in the way. Also, I don't know if I can easily fit a fan over the stock Novak sport ESC and it doesn't have a heat sink. Can't the brushless systems be pushed futher before thermal shutdown?
NY
well, I have the GTB and when i'm bashing in the grass, the batteries and the motor get hot, but usually the ESC itself is pretty cool to the touch. Its actually quite impressive.
This is what I have: http://www.teamnovak.com/products/esc/xrs/xrs.html
No heat sink, no fan.
It's their basic system and came stock in my xxx-t rtr.
So, I'd imagine even the GTX with the heatsink would not get as hot.
But, if I'm gonna upgrade the ESC and motor anyway, why not a brushless.
Sphere Neo 2-star or Novak GTB 6.5
Again, mostly just bashing on the road and low cut grass.
At this point, I'm leaning towards the Novak 6.5
Someone talk me out of it or I'm buying it soon.
The GTB systems should be able to handle your demands MUCH better than the xrs. It just depends on how much you're willing to spend. I would get the Novak 6.5 system as well. You should be pleased with it.
Wow, I got the Novak GTB 6.5 and installed it in the XXX-T yesterday. I ran one battery pack, and this thing flies on the road! Almost too much power. I think any faster and I'd start losing parts. I took it into the grass and it handled well there too. The motor got warm, but the esc was not. So far, I'm very impressed with the GTB. My only comment is that it pauses for a second or two after applying breaks before I can drive in reverse. Maybe this is normal for the GTB?
would the 3.5 brushless be way to much for a xxx-t to handle and if it is than what brushless should i get for my xxx-t so it will go as fast as possible
A 4.5/5.5 GTB will satisfy your need for speed, when it comes to buying a Brushless System from Novak, in your stadium truck.
A 3.5 may heat up more than you would like it to on a stadium truck, but of course, one of the major factors is gearing.
I'd reccomend a GTB 5.5r for a stadium truck. A 4.5r would be very fast, but you'd break your truck just as fast. With more torque using the 5.5r/6.5r or 7.5r, you have much more freedom when it comes to gearing them.
Also to the one who just recently purchased a 6.5r:
Enjoy the system, it is very powerful, and seriously fast. The GTB ESC will rarely give you heating problems, and the motor itself, will run comfortably from 160-180F, however, you will probably never reach that high, 100-130 is what you will usually see using a Flashpoint Temp. Gun, which is just impressive. 6-cells is all you will need with that system. (This is derived from personal experience, being a user of the 6.5r myself)
Enjoy!
Enjoy!
Well I DO run a XXX-T MF2 with a Sphere and Neo 2 star system and beat the hell out of it, I love the thing.
It's a great system, suits the truck well, I'd go with it mate
