Team Losi XXX-BK Brian Kinwald Edition
IN
Does anyone have one of these? I have many questions for it I just bought on today at the races.
-When it takes off it makes a "barking like" sound is this the diff or slipper clutch I tightened the slipper and it still does it[:@]
-What are the best tires to run on packed dirt?
-It also makes a clicking noise when driving (not really loud though)[:@]
I am running a 17 turn motor and this thing flies!!! [8D]
I will post pictures tomarrow![:-]
RE: Team Losi XXX-BK Brian Kinwald Edition
The barking is usually a loose diff. The clicking you are hearing could be the motor coggin (if at low speeds) or a not so hot mesh job on the pinion/spur.
A good 17 turn geared properly will indeed fly. Wait till you start trying to run mod and run a 10 turn single.
I had a BKE back in 2003ish and you will enjoy that buggy, it's on my list of top two RC's I have owned. I definately enjoyed that one.
IN
i got it at an incredible deal too! I fixed the barking by tightening the diff and that also stopped the clicking!!!
My Feedback: (33)
Sounds like you better tighten up that diff or you will be replacing it . The best answer you can get for tires is to ask some regulars at the track you go to . There are a few variables like different tires , tire compounds , and foams .
And not sure by packed dirt you mean hard clay? Or campacked sand?
If its clay run hole shots, if its dirt run bow ties.
My Feedback: (33)
ORIGINAL: Custamizer
is there anything I need to know about this buggy? to help me get better driving it ?
You should buy an aluminum rear pivot block. This really has nothing to do with what you need for it now. Later down the road you will see that this piece breaks all the time. If you hit it right or go off a jump wrong it WILL break. It is also probably the hardest to get to piece.
My favorite tires are the holeshots but I also like the bowties partly because they last longer. Both handle great on hard packed dirt. especially if its wet down.
CA
If you tell us what the car is doing then we can help.Just saying "it handles bad" is not much help.Is it loose?pushing?little of both (it happens)?
