RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
what does pitch mean?
Reply
Old 07-19-2006, 04:29 PM
RCNacraniel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default what does pitch mean?
what does pitch mean when refering to gears (ie. 48 pitch pinion)? Can somebody help?
Thanks for any help.
RCNacraniel is offline
Old 07-19-2006, 04:45 PM
Loswave
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: what does pitch mean?
Pitch is the literal pitch of each tooth in relation to the other. Tha main idea is that you match the pitch between the spur and pinion, if you have a 48 pitch spur, buy 48 pitch pinions, or if you have a 64 pitch spur, then get 64 pitch pinions.
Loswave is offline
Old 07-19-2006, 05:36 PM
Dudelive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.abslotsport.com/page8.html
Look under where it says on the left
UNDERSTANDING “GEAR PITCH”.
As was stated be sure to use the correct pitch, meaning use the same as you have when replacing one gear.
Dudelive
EDIT: Edited to correct the html link
Dudelive is offline
specracer
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
basicly its how big the teeth are on the pinion or spur gear.the higher the pitch the smaller it gets.just think what would happen if you put a pinion with small teeth on a spur with big teeth,wouldent work would it?no
specracer is offline
Old 07-19-2006, 08:45 PM
Rare
Rare's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Dudelive
Dudelive
Broken link, dude!
Rare is offline
Old 07-19-2006, 08:53 PM
Dudelive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry.......link corrected now
You have to put the l on.........dumb me did not copy the link correct.
The easiest way to explain it would be like a nut and bolt. Some have coarse threads (32 Pitch gear) while some have fine threads (64 Pitch gear). You can not screw together different thread types any more than you can use different pitch gears together. Usually coarse gears (32p) are intended for extremely powerful things where you need as much teeth contact surface as possible to stay together. While rc cars and some trucks can use 48p gears and survive fine.
Dudelive
Dudelive is offline
Old 07-19-2006, 11:29 PM
RCNacraniel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can anyone tell what pitch [link=http://www.horizonhobby.com/ProdInfo/SWK/250/SWK5092-250.jpg]this [/link] pinion gear is? It is the one that came stock on my Raven ST. I am looking to replace my pinion, and want to make sure I get the right one/ The item description only says: 20 T Pinion Gear.
Old 07-20-2006, 01:25 AM
Rare
Rare's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: RCNacraniel
did you check your manual?
Rare is offline
Old 07-20-2006, 03:17 AM
bIGmiK
bIGmiK's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like a 48p to me, might be 32 but I really doubt. ST's generally run 48p!
bIGmiK is offline
Old 07-20-2006, 08:44 AM
Dawman
My Feedback: (33)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like 48 pitch . The best way I found to describe pitch is like on bigger gears is TPI [teeth per inch] .
Dawman is offline
Old 07-20-2006, 11:06 AM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, just like the bolts (threads per inch)
Or
Throw baseball
guver is offline
Contact Us Archive Advertising Cookie Policy
