Super Clod Buster Build-up Thread
#2701
NL, CANADA
RE: Super Clod Buster Build-up Thread
ORIGINAL: Lunchboxer
LOL, time to upgrade the steering setup!!
Good to see that the Clod is being used properly!!
ORIGINAL: Mad Racer
After a hard day of bashing the Clod, here are the results:
(For some of you that seen my previous suspension set-up of my Clod of Phase 2, note that the pictures I am using back the cantilever set-up. I use them back, because the way I mount the shocks, wears out the shock mounts and bushings.)
Yulp, well many are thinking that my Clod is a shelf queen where that they see so much aluminum on it, but it's not made for the shelfs. It's a backyard bashing beast!
#2704
For me, I like it stock(ish)... but will be cool no matter which one you go..
Those ESP chassis has been around for a long time, though... have you seen them in person? Just want to give you a heads up on the "look" (no doubt that they work well..) of it.. it is not quite the modern style chassis where everything looks CNC billet... Anyway, keep us posted!
#2705
NL, CANADA
ORIGINAL: TROT73
I was debating between the clodzilla 2 or 4, which do you guys recommend and why?[:-]
But if you do want a Clodzilla chassis, I would probably get 2, since it would probably have less problems than the 4. The problems on the 4 is that some things in the kit won't have the parts you need, which they are suppose to include in the kit. When I purchase this chassis, it suppose to have ball bearings for the cantilevers, which it didn't. I had to find ball bearings and make them fit property in the cantilevers (the ball bearings I had to find had to be really small to fit in those cantilevers).
I don't know about the 2 chassis having any problems, but check out the review of it here: http://clodzone.com/?p=205#more-205
#2706
NY
i ll def keep in touch, i like Clodzilla 2. I seen the clods on different chassis and like the zilla 2 the best. Thats what im leaning towards. [:-]
#2707
NL, CANADA
Some pics that AutoXMan took when we met up yesterday!!
#2711
NL, CANADA
No problem man!
You would be better off with the Clodzilla II, since I don't think it will have problems like the Clodzilla IV.
#2713
IL
ORIGINAL: Mad Racer
I wouldn't get either. Why? The quality of there parts are very poor. I'm still not happy with the Clodzilla 4 that I am running, since I had to do a lot of modding and I'm still needing to do a lot of modding. And I'm always thinking it is not necessary to mod this chassis a lot.
ORIGINAL: TROT73
#2714
NY
haha i think it was by monkeys, i m going to go with clodzilla 2. I read the review and the only problem was the pieces didnt have a finished look on it and a few markings. Its prob an error or something that happened. Anyway 100 bucks on ebay so im gonna order tonight or tomorrow[:-]
#2715
NY
Hey Lunchbox a few pages back you mentioned ( servo at axle steering), ive looked and found them to be $60 each. Why is that better then the stock steering detup and is that a reasonable price?[:-]
#2718
NY
oh and the steering servo on the axle is by rc guy and is selling by the crawler store for $60. So i need one for each set of wheels? Do you know about this kit? Is it any good or is there something better then that?
#2719
It is $60 for a set.. which is for both front and rear..
It is a lot better than stock setup.. take out most of the steering slop.. and don't have to worry about breaking the servo saver / steering crank...
ORIGINAL: TROT73
#2720
There's always something better, no?!
You asked about if the stock setup is really bad and the steering mod is really necessary.. the easy way to find out is really just to run it stock and then see how you like it.. if you don't like it, then upgrade.. how's that?!
I chose that setup for a particular reason.. I want to retain the stock chassis and stock suspension arms.. and to me, in that setting, I think (just my opinion, of course) it is the best setup..
But if you are running aftermarket chassis, 4 links, etc. There's probably one that works better...
ORIGINAL: TROT73
#2721
This was the line up when I met up w/ AutoXMan... !!
Drifting was fun, but there's not beating a monster Clod tearing up the playground!!
#2722
NY
ok thanks lunchbox. If its not to much do you have any close up pics of your truck and any pics of the steering on the chassis
#2723
NY
Also do you know of a chassis called sassy chassis? One of my friends mentioned it. Im going to look into it but any opinion would be great with all your guys expierence
#2725
VA
Heres a few pics of some of my Clods! Got a nib Super coming tomorrow i'm gonna start on. Think I'm gonna build it stock at first!
This one is a JPS I sent off and had anodized Magenta! I also used a Dagger body I painted!
Here it is before I had it anodized!
Heres a Zilla I did not to long ago!
