Super Clod Buster Build-up Thread
#1453
IL
RE: Super Clod Buster Build-up Thread
Upright installed with outer hex drive in place. The hex drive is held in place by a drive pin, the o-ring holds the drive pin in place. These hex drives work with the stock clod wheels.
#1454
IL
ORIGINAL: Lunchboxer
Nice.. that looks super duty to me.. !!
#1455
You got a pic of the stock hex drive? Is it a plastic one? If that's the case, the TT CVD came w/ this aluminum hex drive, make it a even better deal!
ORIGINAL: []TEX[]
#1457
WA
Looking sharp there TEX!!!!
You think I would be in a hurry to complete my Clod....im actually trying to decide if I should finish or turn it into a crawler. Ive been watching and looking at a lot of RC crawling lately.
#1459
WA
ORIGINAL: []TEX[]
Let me finish mine and get some vids posted, should be a good time to make the decision.
#1467
Yes, that's the way to go.......
ORIGINAL: Rare
Thats would help a lot! Thanks TEX! Maybe I should just buy another clod and make it a crawler eh?
#1469
Maybe flip the servo upside down so the servo horn is lower.. you will need a way to route the cable for the servo, but other than that, it should be pretty ideal..
Just a wild suggestion, I don't know how easy it is to route the cable..
ORIGINAL: []TEX[]
I need to do some more adjusting on the servo and links to get them a bit closer to parallel.
#1470
IL
Stage two of the Mass Hysteria paint project. I used Spaz Stix paint systems, it is a three part application. This is the first two steps.
A pre-prep spray that gives a surface for the color change spray to hold on to.
Second is the color change spray, the entire can is required for this step, man my finger is tired..[:'(]
The colors are Blue/Purple/Red, none being dominate.
Hard to see, but a little on the edge. The body would be perfectly clear otherwise, step two gives the foggy appearance.
#1475
Geez, big timing everybody with your fancy paint.. (joke)
Definitely looking forward to seeing that in person for sure!! We will have a winter bash, eh?! (maybe go find CT4L this time?! ha ha!)
