Super Clod Buster Build-up Thread
#1477
IL
RE: Super Clod Buster Build-up Thread
ORIGINAL: Lunchboxer
Geez, big timing everybody with your fancy paint.. (joke)
Definitely looking forward to seeing that in person for sure!! We will have a winter bash, eh?! (maybe go find CT4L this time?! ha ha!)
This has been keeping me in a good mood considering the past few days.
#1482
IL
ORIGINAL: Rare
Nice TEX!!!!!![sm=thumbs_up.gif][sm=thumbs_up.gif]
I quick glance at all three colors...
#1485
IL
ORIGINAL: PsYkHoTiK
Thats a real nice paint job!
Just got done soldering the motors and wiring. Bench tested the T600s, twin motors sound great on 14.4V
#1487
IL
Interesting note on the TT ball differential.
I was curious as to why the diff had three sets of ball bearings. Well, now I found out why. With the motors not installed the differential would free spin fairly easy. This worried me because it was very loose. I just didn't notice the gears spinning in the case as the diff counter rotated. basically when I spin one wheel the other spun in reverse.
With the motors installed, the diff is very stiff now. I am definitely relieved!
The motor does not allow the diff gear to counter rotate, allowing the inner main ball race to do the work.
Finally I get some high tech gear too....[8D]
#1488
LOL... I am sure that thing will require some adjustment to get it to run perfectly.. but once it is dialed.. it should be pretty awesome!
You can hold up one wheel and see how much power is the other wheel transmitting.. to see how much of that limited slip effect you are getting..
#1489
IL
#1491
IL
Yeah, I am sure my neighbor always wonder what's going on next door with all the machining sounds, etc. Hee hee..
#1492
You said they make it for TXT too, right?! The ball diff, I mean..
Argh... I think I will run it as is for now... too much $$$ into the TXT already.. LOL! [:'(]
#1493
Nice paint job. Looks like the F-650 body? That body is not so good for aerodynamics but it is bullet proof and has good details. Super thick lexan saved my TNX a few breakages while I learned how to jump properly.
#1495
IL
#1496
IL
ORIGINAL: secretsg
Ya, it's as thick as my Grave Digger body....nice and tough.
#1498
IL
Hmm...well I can tell you the paint chips off very easy. So much for profesional paint systems.[:@]
Whatever, I am not stressing over it.
#1499
Take a lot of pictures before you start bashing w/ it.. cause it will not look like that soon...
Got a complete chassis shot yet?!
#1500
IL
Well, I am a tad upset about the paint, but that's how it goes. Trial and error...[&:]
So here is the set up. Going to glue the tires and then send her out on a maiden voyage.
