Super Clod Buster Build-up Thread
#1776
WA
RE: Super Clod Buster Build-up Thread
Well, whats a good wheelbase for Clod racing? Right now im at a 14" wheelbase. I was thinking 14" is perfect. What do you guys think?
#1777
CA
Ok i built my axles first to test out the wheelbase. 19" really isn't bad... I also put some wideners on it. . I just need a body big enough for all of this.. see how things pan out.. almost done with stock build. should be done by tommorow.
#1779
IL
ORIGINAL: mindwreck
#1781
CA
19" wheelbase stretch. know anywhere to get 1/5 bodys? i don't know of any and tower doesn't.
pretty much done with stock build.
#1782
CA
inet ones for the TLT or any 12mm hex wheels
ORIGINAL: Lunchboxer
What kind of wideners do you have?! Post some pics!!
#1788
Ah, I think I see it now.. TXT has a similar setup.. except the hub is quite big, so I didn't realize they are the same thing.. also, different color..
My bad.. (the TXT hub is gray..)
#1789
CA
okay im tired of the msc... its just jerking all over the place, Theres too much slack in the ball cup and it doesn't move the lever enough to go into neutral. just constant forward and reverse. tore my room apart after giving it a test run indoors....[:@]
#1790
LOL.. MSC = old school there..
I think Tamiya needs to start equipped their big trucks w/ stock ESC.. like Kyosho's Twin Force Spirit.. that would be nice!!
#1799
CA
i just picked 8 of those for a savage on ebay for 50. They're ~1 inch longer so it should raise the clod a bit. the stock shocks just bounce and sway too much without oil
