Trailer build-off thread!!!! (Please join!)
#52
CA
RE: I made a trailer!!!
ORIGINAL: lee172
very nice work, maybe i'm going to far with this, but you could mount a spare wheel on there!
Believe it or not I thought of that but it cost too much already. At least with the wheels and tires can be used on the truck too and rotated. I also thought about a tool box on the front, to keep the tie downs in
rcluke. I didn't keep track of the cost but I'm guessing $75.00 - $100.00 I had to but all the wheels, tires, axles, knuckles, angle aluminum, wood, hinges, nut's, bolts and flat bar aluminum. The trailer frame and ramps only took about 4 hours but the fenders took a lot longer. They were a bear getting them just right.
#56
I agree I think i might HAVETO make myself a trailer now after seeing all your good work
i might just make a simple one to start with, then maybe modify it (neons, big rims, low profile tyres, (the essentials))
rcluke
rcluke
#62
http://www.mcmaster.com/ has an array of building material. Aluminum, lexan, plastic, you name it. They have bars, tubes, cubes, sheets, balls, and other stuff.
#65
CA
ORIGINAL: rcmaster103
raz!!! I hate you!! lol Very nice trailer. I need to finish mine. I need some more materials now.
You are the one that inspired me to finish mine so it's all your fault
#71
CA
Thanks, I appreciate that. I finally got around to grinding the bolts down flush so they don't stick out now so it looks even nicer now.
#72
ORIGINAL: raz54
Oh no, am I going to have to install that spare tire on mine now just to keep up (lol)?
Dudelive
#73
CA
ORIGINAL: Dudelive
You could think about an overhead tire rack for the trailer up front out over the hood of the car as some of the real trailers are. Then a tool box on the tongue. Looking Nice
Dudelive
ORIGINAL: raz54
Dudelive
I like it! Thanks.
#75
CA
Sounds good to me, I accept the challenge. I think we should allow anyone else to join in if they want to and we would need a cut - off date and then a poll to decide the winner. Since this was your idea I'll leave it up to you.
