RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
HBX, Who else owns one??
Reply
Old 02-02-2013, 12:44 AM
  #5076
Manimans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: HBX, Who else owns one??
@phmaximus
Thanks for very descriptive reply, i am just a beginner in the rc world. I have a HBX massive 4x4 brushless truck, it has the hex with pin inside, there is a lot of play in the front wheels plus one is shaking like crazy it needs balancing and i have no experience on how to do it. The car has a lot of power but looks like the parts are not up to it. Slowly i will replace em when thet wear out completely, i am getting a lot of help from this forum, thanks to everyone out there!
Do i still need the shim set or just balancing?
TIA
Manimans is offline
Old 02-02-2013, 06:48 AM
  #5077
DieHarder
DieHarder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If they are lock nuts, there should be like a nylon washer type peice inside the nut. (Just incase you weren't familar with lock nuts. I didn't mean to make you feel ignorant, I just thought I'd put it in there just in case. ) If they aren't lock nuts, then you NEEDto get some. I beleive they are 4mm lock nuts, but I suggest you check anyway before you buy some.
Quote:
ORIGINAL: Manimans
@DieHard1207
Thanks for the headsup ! I will look for that glue, i hope local ACE store has it.
And No there is no washer. Now i doubt the nuts are even lock type, maybe the are just regular nutS?
TIA
DieHarder is offline
Old 02-02-2013, 04:02 PM
  #5078
DieHarder
DieHarder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey,
Last week I built a straight edge plow for my 4x4 Cross Tiger. It was all stock and barely pushed any snow. So I put a brushless system in it and reformed the plow with a curve, a v-shape, and a new mounting system. I took the pictures before paint. I painted it a while ago, and it should be dry by tomorrow afternoon. I while I was waiting for it to dry, I took it out for a run. The first pics are a little bashing with brushless, and the second ones are the new plow.
ID:	1847252   Click image for larger version
ID:	1847253   Click image for larger version
ID:	1847254   Click image for larger version
ID:	1847255   Click image for larger version
ID:	1847256   Click image for larger version
ID:	1847257   Click image for larger version
ID:	1847258   Click image for larger version
ID:	1847260   Click image for larger version
ID:	1847261   Click image for larger version
ID:	1847262   Click image for larger version
Old 02-02-2013, 06:14 PM
  #5079
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Manimans
@phmaximus
TIA
both, start with shiming, once u get it all shimmed u can actially ballance those big wheels on the axles, just remove the dog bones.
I use to have a HBX rocket, from what i can see its the same just a buggy version?
we are here to help, serioulsy ask anything, dont feel silly.
phmaximus is offline
Old 02-02-2013, 06:18 PM
  #5080
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: DieHard1207
Hey,
that is so cool, how well does the plow work? could u fit a servo to it to adjust hight? u could use a 3rd CH
might have to get my bonzer cranking again, I striped a diff cup and its sat since lol
Old 02-02-2013, 07:12 PM
  #5081
Manimans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Are tamiya parts compatible with HBX? Earlier DieHard has suggested me to use the TL01 gear mesh for my HBX, and robinson pinion? Can i use them with my motor, what about the Spur ?
TIA
~Mani
Manimans is offline
Old 02-02-2013, 08:11 PM
  #5082
DieHarder
DieHarder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks! I haven't tried out the plow yet. Over here in Michigan, it's only 11:02 p.m., so my plow is still sitting out in the garage drying. Can't wait to try it out tomorrow! I was going to use a 3 CH and servo, but I don't have a 3 CH. I have a few good servos, but a 3 CH is on my To Buy list. Eventually, when I get a Savage XS Flux, it comes with a 3 CH and I plan on putting the plow on that. But for now, I am going to try it out with the HBX. I thought about pulling the tires off the rims, (Since their not glued on) and drilling holes down the center tread, and putting sheet metal screws in the holes with a nut, and havingthe head on the inside of the tire for more traction. Do you follow? I thought about this, and then I figured it may not be a good idea, because in the summer, when I'm running speed runs and bashing, those studs are going to rip and throw everything. I thought then, if I removed the screws in the summer, I'd have holes and thetires would fill up with dirt.
Sowhat do you guys think? Should I stud them? I'm sure if Idid, I would have no problem with traction?Wouldthe studs work in the summer?
Quote:
ORIGINAL: phmaximus
Hey,
Old 02-02-2013, 08:19 PM
  #5083
DieHarder
DieHarder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The spur gear comes in the Tamiya gear set. http://www3.towerhobbies.com/cgi-bin...?&I=LXGL57&P=7Also with those gears, in order for the pinion to mesh right with the spur, the pinion has to be metric. I suggest you do a 19T, as they seem to be the best gear ratio. http://www3.towerhobbies.com/cgi-bin...?&I=LXEX42&P=7Not all Tamiya parts are compatible, but the vehicles that have the most compatible parts are the TL-01 and the TT-01. The metric pinion should screw right on to your motor's shaft.
Quote:
ORIGINAL: Manimans
Hi,
TIA
~Mani
Old 02-02-2013, 08:43 PM
  #5084
Manimans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Kindly see the attached image, i dont see the 'highlighted' part in the Tamya gear sets that you had recommended earlier. And as for the Pinion, i also noticed the original HBXSpur and Pinion set has more teeths then the one you had recommended. Since i am new to this area could you explain a bit whats the ratio between pinon and Spur or is there a rule of thumb for pinon and spur selection?
~Mani
Manimans is offline
Old 02-03-2013, 04:53 AM
  #5085
DieHarder
DieHarder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh............ I didn't know you had that type of truck. Um.. Could you attach a picture of the truck you do have?
The rule of thumb for gear mesh, is you take a regular peice of printer paper, cut a strip about 4cm long, and 1cm wide. It doesn't have to be perfect. Then stick the peice of paper length wise into the gear mesh between the pinion and the spur. Then press the two gears together so the pinion moves to the correct position in the slot, and tighten down the screws. Roll the spur to roll out the peice of paper, and you have a perfect gear mesh. If it seems too tight or too loose, or if it's making a sound, then you either didn't pinch hard enough, or you pinched too hard. You can adjust it slightly by partially loosening one of the screws, then tapping the motor over a bit, and tighten the screw back up. Or you can just start all over with the peice of paper. Eventually you'll get it right. Maybe you'll get it the first time. The more you do it, the better you get at it.
Old 02-03-2013, 11:46 AM
  #5086
Manimans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I have this truck but with brushless motor.
http://www.elitemodelsonline.co.uk/P...-BRUSHED-MOTOR
cn you tell me the stop function is a feature of remote or ESC, my car doesnt stop properly any more rather i have to use reverse function to stop it, what could be the reason?
TIA
Manimans is offline
Old 02-03-2013, 03:03 PM
  #5087
FenDogz
FenDogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been lurking around these posts on the hbx topic and found that my sons truck the iMex renegade is the same as the hbx massive. So I guess I can now say that we own an Hbx. :-)
FenDogz is offline
Old 02-03-2013, 03:25 PM
  #5088
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just rember this thread was for the HBX bonzer that is a clone of a Tamiya TL01b BajaKing, but HBX used monster truck wheels and a mt body.
99.9% of the parts are interchangeable, the only thing Is... HBX have a longer gear shaft and will not work with a Tamiya chassis
The HBX massive or rocket is not compatable at all with any Tamiya. Or even the bonzer
Old 02-03-2013, 03:28 PM
  #5089
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Manimans
Hi,
TIA
The breakes are controlled by the ESC, what setting do u have them set to?
If its the lansu I wouldent have a clue if it's even possible to change there settings
Old 02-03-2013, 08:31 PM
  #5090
Manimans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is a Lansu
Manimans is offline
Old 02-04-2013, 05:07 AM
  #5091
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is not much u can do, to improve braking with that esc [&o]
Old 02-04-2013, 08:48 AM
  #5092
DieHarder
DieHarder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally had a chance today to try out my snowplow! It plowed great, I'd say at an easy rate, it can plow 3-4" of snow. Here are some pics. (Below the deck was the only place that there was 2-3". Everywhere else was a foot or so.)
ID:	1847929   Click image for larger version
ID:	1847930   Click image for larger version
ID:	1847931   Click image for larger version
ID:	1847932   Click image for larger version
ID:	1847933   Click image for larger version
ID:	1847934   Click image for larger version
ID:	1847935   Click image for larger version
ID:	1847937   Click image for larger version
ID:	1847938   Click image for larger version
Old 02-04-2013, 02:19 PM
  #5093
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lol thats so cool, now i have the MR.PLOW song stuck in my head from the Simpsons
Old 02-04-2013, 03:08 PM
  #5094
DieHarder
DieHarder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bad news with the plow. My mounting arms are bending and the screws are coming loose, causing the plow to come closer to the truck. [:@] I'm going to have to put some 90* bends in the arms and I need to make them longer so I can make more of a V-shape. Also, as you can see, I couldn't push snow very far before the wheels started spinning. So what do you think? Should I put sheet metal screw studs in the center tread bead?
Also, should I make it a straight plow instead of a V?  I thought about doing an angled plow but I figured that it'd push the front end over in the opposite direction of the snow. Before I can do anything more, I need some more sheet metal. [:@]
BTW, thank you for the complements.
Old 02-04-2013, 06:55 PM
  #5095
Manimans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome machine!!!
Manimans is offline
Old 02-04-2013, 06:59 PM
  #5096
Manimans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[youtube]http://youtu.be/4alHkZR89XM[/youtube]
Hey guys check it out
Manimans is offline
Old 02-04-2013, 07:38 PM
  #5097
DieHarder
DieHarder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dunes are ALWAYS fun! Thanks!
Old 02-05-2013, 11:32 PM
  #5098
Manimans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Forum,
Since my break function is not working, and there is no way i can program my Lansu ESC, can anyone suggest me a good ESC for my truck, it has a Leopard LBH3660 Brushless Motor.
TIA!
~Mani
Manimans is offline
Old 02-06-2013, 03:16 AM
  #5099
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just wondering, do u have breaks in reverse? its very possible its setup backwards. It should have something?
This is the motor right? [link=http://gcmodel.en.alibaba.com/product/465416190-212195769/Leopard_LBH3660_8T_3600KV_2_Poles_Inrunner_Brushle ss_Motor.html]here[/link]
But if u are after a very reliable ESC with all the setting u should need
I would be looking at the Ezrun 60a [link=http://www.ebay.com.au/itm/EZRUN-60A-Sensorless-Brushless-ESC-RC-1-10-Hobbywing-Car-Buggy-V2-/281019740479?pt=AU_Toys_Hobbies_Radio_Controlled_V ehicles&hash=item416e14f13f]here[/link]
Im positive the 35a version will be fine but for the extra $8 its worth getting the 60a version and it peaks to 380a
Old 02-06-2013, 03:52 AM
  #5100
Manimans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Thanks for the reply!
Yes you are right about the break part, actually the Controller that i have has three Throttle positions, 1) Accelerate 2) Neutral 3) Reverse. The break function is suppose to work when we move from accelerate to Reverse directly withouht going to neutral, which will actually activate Reverse not break and that is not good for the gears.
It looks the same motor only mine has a purplish body i am not sure if its a different model, as per HBXmanual and specs i am suppose to have a 2600KV motor but the Leopard specs says its 3600KV... i am not sure who is right?
The ESCi have is Lansu 90A!
Below is the link to the user Manual of my Truck, it explains the Reverse/Break functions on Page-5 clearly:
https://dl.dropbox.com/u/68942087/hb...pro_manual.pdf
TIA!
~Mani
Manimans is offline
Reply
Display Modes
