Need Urgent help have 1 hr will this work
RE: Need Urgent help have 1 hr will this work
Hey am If i did get a brushless system right how fast would i go and also is their any possible wya to use a brushless system frmo a plane on it i mean it is so much more cheaper .?
can someone tell me what like a 8T, 10T, 18T etc is? i am looking at a Dark Impact buggy and a Team Losi XXX-CR, would some of these motors fit in it?
GA
sorry had problems with my comp but am back now ...hopefully. it runs hard for 5 min. then gets slower gradualy
dont know man all i know is that the lower the # as far as turns are considered the fastest imagine a 2t
#39
hey i have 2 esc in mind now the novak super rooster or the novak cyclone that way i can buy cheap 10 t motor and use it up lolz how fast will i go if i use the 10 t with my 2000 mah battery pack?
#42
GA
#43
plz, if i get the team losi XXX-CR or XXX-BK2 would any size motors fir in them? is there like an ajustable place to slot them in? Or can each car only have an exact dimension for the motors?
#44
damn so what ill get like 2 mins and then a car is going to run it over lolz no but seriuosly these are what my plans arei am going sort of affordable ok first.
-Buy either the novak super rooster or the novak cyclone which I am buying because they have no limit I am buying one of of ebay the only thing wrong with it is that it needs a new switch for the receiver the last one something happened with it so ill put on a new on get one from cheap battery packs .com
-buy a nice 8t motor for like $50 buy the fan cooling heatsink thing.
-buy some hpi slicks to burn rubber literally
-then start to upgrade chassis part
#46
ON, CANADA
I think you need to learn some more before you go 50mph, like that all 540 motors are the same size and what motor turns are. 50mph is ridiculously fast and 2000mah cells and no name cells are worthless in this application. Just don't spend a ton of money before you realize that you don't like this hobby.
#47
MD
ORIGINAL: Phatmat
#48
ON, CANADA
If you want to go 50mph dont forget to buy an fm radio system and tranny upgrades. And find a big place to run. I'm not sure if rubber tires will handle 50mph, look into foams. Foams are more expensive and dont handle burning well. I doubt your going to be able to reach 50mph and being able to spin you tires anyway, your goin to have to overgear alot to reach that speed.
#49
dude am I am not new to the hobby just new to electrics ok I have a schumacher fusion a savage a hpi super nitro 2 hpi rs4 so I am pretty well of in nitro and foam are no big deal i have enough foam tires also no plans to get out of the hobby i will modify like crazzy the reason i am starting of in electric now for is because I want to be able to keep a clean body lolz.
