RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
deans vs tamiya connectors ??????????
Reply
Old 01-24-2007, 11:57 AM
mark.b
mark.b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default deans vs tamiya connectors ??????????
i hear people rave on about deans connectors and others say they are happy using the standard tamiya style , can some body tell me if there is any advantage over using either over the other one
mark.b is offline
Old 01-24-2007, 12:13 PM
zephar123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: deans vs tamiya connectors ??????????
tymia plugs are heavy resistence meaning alot of heat on your batteries, lowers runtime and performance. Deans plugs are low resistence meaning longer run times and cooler batteries and better performance.
zephar123 is offline
Old 01-24-2007, 12:14 PM
Josh222
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also if your running anything remotly fast tamiya plugs tend to fuse together and have to be cut off
Josh222 is offline
Old 01-24-2007, 12:17 PM
Eman77
Eman77's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TrueBlu - It's not that Tamiya plugs won't work at all - they function fine in stock type setups. (I ran them with GP3300s and a 19T buggy without melting issues). But if you look to upgrade for speed by spending $$ on IB4200s or something, 7 cells, faster motors, etc - you're kind of shooting yourself in the foot if you keep Tamiya plugs, as the resistance is holding you back.
Deans is a cheap upgrade, so go for it. Powerpoles are also supposedly low resistance and easy to install, so look into those too!
Eman77 is offline
Old 01-24-2007, 12:24 PM
raz54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is no comparison. I've had Tamiya plugs melt together even with stock motors and low mAh batteries. Tamiya plugs are junk end of story.
raz54 is offline
Old 01-24-2007, 12:45 PM
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The resistence in the Tamiya plug can be high as the contact surface sometimes don't mesh too well with each other.. (just study the construction of it and then take a look at the Dean's plug..)
For regular stock setup, it works okay, unless you don't set it up right (i.e., you are pulling too much current due to incorrect gearing, etc.)
But for brushless / higher power setup, when the motor is pulling a lot of current, the Tamiya plug tends to overheat and then melt.. I melted mine when I was testing my LRP Sphere / Neo brushless setup..
After that, I just decided to change everything into Deans..
Lunchboxer is offline
Old 01-24-2007, 04:02 PM
rc monkey
rc monkey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Deans work and Tamiyas don't (my experience)
rc monkey is offline
Old 01-24-2007, 04:10 PM
lee172
lee172's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so then your next question might be Deans vs Powerpoles!!
lee172 is offline
Old 01-24-2007, 04:15 PM
flynvy5
flynvy5's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
powerpoles are ok but you might want to watch that the connection stays inplace i was using powerpoles on the loop for the track and we had an issue one week that the connection wouldn't hold found out the positive had pushed back into the caseing just my experince
flynvy5 is offline
Old 01-24-2007, 04:20 PM
mark.b
mark.b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well its looking like im gonna be busy soldering soon , i need the practice any way , new connectors on batterys , charger and esc's ,
mark.b is offline
Old 01-24-2007, 11:23 PM
JUCD VPR
JUCD VPR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get DEAN'S. Man i cannot tell you how many tamiya plugs i have melted/fried, THEY SUCK!
JUCD VPR is offline
Old 01-24-2007, 11:58 PM
Silentbob343
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: trueblu
I recommend the EC3 connectors by eflite. They are gold bullet style plugs in a plastic housing, easier to solder and pull apart. They cost 2.99, so about .$50-.75 more than Deans Ultras, but I feel they are worth it.
I started with deans because that's all anybody ever recommended, but when I bought the quake I redid my connectors with the EC3s.
Silentbob343 is offline
Old 01-25-2007, 11:08 AM
Bob=)
Bob=)'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i use powerpoles because they rulezorz!!!!!!!!!!!! XDXDXDXDCDXDXDXD
Bob=) is offline
Old 01-25-2007, 11:33 AM
running_gag
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
huh?
running_gag is offline
Old 01-25-2007, 12:01 PM
bIGmiK
bIGmiK's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used both deans and power poles.
I didn't notice and different in power between the two.
I use deans on all my RC's now because they are easier to use, and you don't need to worry about using the wrong polarity.
bIGmiK is offline
Old 01-25-2007, 01:22 PM
Jeckler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use Powerpoles on all my RC's now because they are easier to use, and you don't need to worry about using the wrong polarity.
Jeckler is offline
Old 01-25-2007, 03:47 PM
Rs43EVOman
Rs43EVOman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, i have never had problems with the tamiya's. I notice it seems like the guys who are expierenced and actually know there stuff are the ones saying more then just "deans rule tamiyas suck". Tamiyas work fine if your running a higher-turn motor set-up, and not doing anything too serious. If your racing, or have a fast set-up, then you want the deans. Its not that there some incredible discovery that makes your car 10X faster, becuase you probably wont even notice a power difference between deans and tamiya's, its that they are a cheep thing, and they do handle faster set-ups better, so why not use them.
Rs43EVOman is offline
Old 01-25-2007, 03:52 PM
lee172
lee172's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i guess its all or nothing, cos once you have Deans on one car, all your batteries have to be 'Deaned' unless you mix and match between Tamiya and Deans, ive just tinned my first wire!! at long last!
lee172 is offline
Old 01-25-2007, 05:14 PM
Doahh
Doahh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"you probably wont even notice a power difference between deans and tamiya's,"
YES YOU WILL!!! Deans are a major upgrade, cheep and you will notice the difference.
Doahh is offline
Old 01-25-2007, 05:27 PM
mtdoramike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I fried my Tamiya connects and was using a 1500 battery with the manual speed control. I just installed Deans on all my stuff and I can tell you, I notice a difference.
mtdoramike is offline
Old 01-25-2007, 11:42 PM
zephar123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
put it this way all rookies come to the tracks first thing we have them change out is there tymia plugs to deans. this alone usuakly increases speed by 50%!!! and alot of times adds 2 or more times to there runtimes.
Old 01-25-2007, 11:52 PM
rcxboy
rcxboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: zephar123
I hope that's sarcasm.
rcxboy is offline
Old 01-26-2007, 12:03 AM
Slo-V Flyer
Slo-V Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah I hope so to.
Seriously though, from my own experience I can tell you I *did* notice a difference in runtime AND performance.
I have a Traxxas Bandit and Rustler, I used to have Tamiya connectors on both, the Bandit running a 12t motor and a 15t motor in the Rustler. If I ran them on 7-cells, or ran them at higher gearing, the connectors WOULD heat up a lot, OR they would simply heat up anyways and melt together if I ran too long of a time using 1800 or 3000mah batteries. After I switched to Deans, I noticed the same batteries gave me better runtime (went from 8-9 minutes to 10-12 minutes) AND I had better overall punch and top speed (I could just about tell), without the fear of melting connectors if I popped too many wheelies or gunned the trigger hard too much.
So bottom line is yes, if you want better runtimes, and you think you want some speed, OR your connectors heat up every now and then, then go ahead and upgrade to Deans. I mean you can also argue why upgrade to from bushings to ball bearings, too, right? It's simply more efficient. [8D]
Slo-V Flyer is offline
Old 01-26-2007, 12:16 AM
Silentbob343
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I still say EC3s
Old 01-26-2007, 04:10 AM
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Easy way to find out just how much difference it make.. measure the resistence across in a Tamiya connection and compare that to a Dean connection..
If only I got some Tamiya plugs lying around... argh!!
Contact Us Archive Advertising Cookie Policy
