Modified Motor? 17 Turn?
I'm curious if a 17 turn motor is considered a modified motor? I'm looking at the Team Associated T4 RS RTR and it comes with a 17 turn motor. I want a good electric truck to race, but I want to run in the stock class. The hobby store is trying to sell me the XTM X-Cellerator which does look cool but they said I'd have to up grade the motor to be competitive on the track. Also, I've owned to Associated buggies before and they were great. Any advice between the two cars and what makes a modified motor? THanks,
JEff
JEff
RE: Modified Motor? 17 Turn?
ive got an xtm racing x-cellerator the electric version, its a great car very tough!!! i changed the motor because the stock motor is only 27 turn so i bought a team orion maethod motor which is great. plus if you did this then you would not need to splash out on new esc. the venom racing fireball motor also seems to be a cheap motor that is a 17 turn modified
CA
One thing to note, though, the Venom fireball motors aren't that great; the 19t Money is faster than at least te venom 15t, if not lower in some cases.
My Feedback: (7)
airsavage i have that truck. t4 race spec. the stock motor that it comes with (reedy radon 17turn) is not very good. if you get it check the motor capaciters mine only had 1 and should have 3. associated sent me a new motor for free but it's still not very fast. i've heard alot of good about the checkpoint money motor 19turn. the t4 is a great truck. the only upgrades i'd do would be rpm a-arms.
ORIGINAL: fourwheels0
I can vouch for the Money 19t. Its much better than the stock 17T high rpm Tornado my Sprint 2 came with. Its a bit faster but gets tho top speed twice as quick. Much torquier. The slightest turn at full throttle sends it spinning out on asphalt, and its 4wd with HPI xpattern street tires.
WI
The T4 is a great truck, as long as there is parts support, get it. Don't take any of the above advice on motors because stock class is 27t. Get the co27 from trinity. It is one of the best stock motors out there now. The reedy radon is not a very good motor anyway.
Well it depends, if you want to race stock class then get a co27 trinity motor. BUT, if you wanted to you could also race in the 19t spec class and then you could get a checkpoint 19t money motor and race that. Its all up to you.
P.S. Oh and I'd go for the associated t4.
My Feedback: (51)
ND
I'd also look at the Chameleon 19t pro. I've got one that came in my DI and it's great. Enormously better then the Raven I tried, I've got a 12t Speedgem coming to try also.
ORIGINAL: cubmaster
Sorry man but in my opinion the chameleon 19t doesn't even compare to a checkpoint 19t or a komodo drangon 19t. Speedgems however are a good motor.
