Official Mamba Max Thread!!!!!!
#803
MN
RE: Official Mamba Max Thread!!!!!!
hey all, just got my mamba max 5700 a month ago and its great to finally be able to run it over and over and over and never have to worry about brushes wearing out and such!
also am just getting use to all this power in the snow!
#806
CA
ORIGINAL: kyrus
I thought I'd repost this in the hopes that someone can help me out. Question: Are there any alternatives to getting rid of the annoying stuttering problems other than soldering the motor wire together? I have both the 5700 and 6900. I'd rather not be locked into a motor choice by not being able to change easily. Settings are as mild as it comes. I have Tenergy and GP packs, JR XS3R radio in my T4 --- the car is giving me fits.... Help !!!
#807
CA
ORIGINAL: juggaloRCist
i'll have to try it thanks. does shortening the wires really help that much?
#808
Hi, i have a rc10t4 with a mamba max 7700 system and a 9 cell 4200 battery, my question is i am after gearing that will give me fast starts high speed runs and the gearing to wheelie throughout the whole speed range, i have a wheelie bar so flippings not a problem i just dont know what gearing to use to get the best of everything with the power to wheelie on demand, any help woulg be great.
NY
ORIGINAL: lil_ashy
9 cells on the 7700, thats nuts, the motor is rated for 8 cells, what are your temps on the motor.
#810
TX
I run 4s1p A123 on the 7700kv. You have to watch the temps and willing to sacrifice your batteries. It sucks alot of juice.
#812
my other batteries are 6 cells and thats what i use most but show off with the 9 cells as it is silly fast, (snapped both my cvds clean in half last show off session)
#815
OK guys read the entire thread and didnt come away with a very definative answer...Although there is no "definative" answer to my question.LOL. I just picked up an Xl rustler, I also grabbed the 5700 motor with the Mamba esc, I will be using a max amps 2s 6000mah lipo with talon tires on it. Could someone tell me where to start gearing it? I still have the stock 86T spur in it and would like to keep that spur as I purchased a few in case of stripping them...I would like a well rounded gear as I will run this on everything from short grass to dirt to pavement. Thank you for any help.
#818
NY
ORIGINAL: halls
I have evader st and mamba 6900 ordered and on the way what spur should i use 81 or 87?
batery i have is 3300 3600 nimah.
#819
AR
I'm getting a 2s 8000mah for my 5700mm. I'm afraid with a 3s it will have two many heat problems.
Is anyone running a 2s on the 5700??
And how fast does it run compared to a 3800 6 cell nimh battery??
#821
ORIGINAL: superfrog
I dont have a 3800, I have a 4300. I cannot give you specific speed figures but the Hyperion is definitely faster off the line and lasts longer, and runs cooler.
Speaking of cooler, I bought an aluminum battery cover specifically to help my NiMH cool better. Now I use Lipo, the cooling is not necessary.
I can hit almost 100deg C on the motor with the 2S.
I assume you are getting the Maxamps 8000?
#822
MO
#823
AR
ORIGINAL: nauticar
Im running a Hyperion 2S on my DI (MM5700).
ORIGINAL: superfrog
#824
RI
Hey guys, Im new to electric RC...im been running nitro for a few years but wanted to try electric. I picked up a used duratrax evader and put a mamba max 7700 in it. Im running 4600 NiMah Ener-g 7 cell packs and this thing really cranks. The problem im having.....besides too many wheelies and melted gears........is this. I seem to lose steering from time to time, which can be a problem at 50 mph. It seems to always happen after I let of the throttle................ Im not sure if this is a receiver issue or if it has something to do with the speed control cause it lets out a few tones now and then. It also seems to happen after about 10 minutes of run time.
Well im learning as I go here. If anyone has any ideas please let me know
ORIGINAL: stasoccerkid
http://www3.towerhobbies.com/cgi-bin...&I=LXRXY0&P=ML
what do you think is better that on a momba
