velineon or mamba
#226
RE: velineon or mamba
My video is made and uploading. My youtube name is NoShelfQueen. It will be up later tonight. I'm going to dinner, but keep checking, should be up within the next 10-20 minutes.
http://www.youtube.com/user/NoShelfQueen
I have some using the VXL esc too. In this video is shows literally 0 cogging. Plus tons of HP.
#227
UT
ORIGINAL: VVRC
Someone needs to take a freakin' MIDOL...AND NO you are wrong it is not the ESC's that COGG it IS THE MOTOR!!!
Actually the cogging effect (technically known as detent)
is due to pole construction. The windings have no effect.
The cog or detent is the point at which the center of the magnets
perfectly line up with the ideal magnetic path through
the poles.
This detent can be sharp or soft depending on pole construction.
A straight pole (no twist) along it's length will have
a sharp detent.
A twisted pole will have less. This is because for different
points along the rotor the magnetic "perfect" point is at a different
point in the rotation of the rotor.
Pole shape also has a factor in the detent amount as does air gap between the rotor and poles.
The drawback is loss of torque, high detent motors have higher
peak torque and better efficiency than low detent motors.
The positives are smoother operation.
The motor will not detent/cog at zero current if
there is no magnets in the design. No magnetic
force = no cogging.
Take a midol....bro!!
the poles.
a sharp detent.
force = no cogging.
I'm an integrated engineer, what are you?
#229
ORIGINAL: supercharged347
I see so many people say the VXL is bad with cogging....I have yet to experience any cogging at all. I run a good lipo, I know weak nimh cells can cause problems sometimes. Maybe some people need to upgrade batteries ? Or maybe I am just lucky. I was really suprised with how smooth it is.
http://www.youtube.com/watch?v=pKdRFDuyoVo
#230
PA
ORIGINAL: Access
If you want to see cogging, try creeping along at speed less than 10cm per second. Unless they've made some revision, it starts to make what almost sounds like a clicking noice and will eventually just shut down if you do it long enough. At least that's what it did for me, I posted a video:
#231
I'm not sure where people get these explanations... seriously cogging is much simpler than this.
In RC we use the term 'cogging' to refer to the what happens in some BLDC sensorless systems when you try to go very slow.
Again see the video I posted above to see what cogging looks like.
The Back-EMF method to sense the rotor position stops working somewhere between 60-300rpms depending on the precision of the ADCs or whatever other sensors they are using to measure back-EMF. Below this the ESC has to use some other algorhythm to start the rotor spinning. A sensored motor and ESC combo does not have this problem at all, it can tell the location of the rotor even at rest. That is why the GoaT is really the only BLDC setup that works well for crawling. Anyways, among sensorless ESCs, this quality of this starting algorhythm is what determines the level of cogging. If you try the mamba max with the original firmware there is some cogging. But with their latest version (used in the video above) you can see that they have almost completely eliminated the cogging at low speeds. It's still not controllable enough for crawling, but out of all the sensorless ESCs I've used it does the best in this respect.
That a firmware update can change the level of cogging should alone rule out the below explanation; if a firmware update can fix it then clearly it is the ESC that is the cause and no the motor.
ORIGINAL: VVRC
the poles.
a sharp detent.
force = no cogging.
the poles.
a sharp detent.
force = no cogging.
#232
PA
ORIGINAL: Access
ORIGINAL: VVRC
the poles.
a sharp detent.
force = no cogging.
the poles.
a sharp detent.
force = no cogging.
#233
ORIGINAL: vge
Wow, now I have truly realized that some people have way way too much time on their hands. Why in the world would you even run your rc that slow? I mean come on now. I can't believe people are really bickering and complaining about that. If that is what "cogging" is you people are straight retards. I guess I have never seen it before because I have never driven any of my rc's that slow before to notice. As a matter of fact I don't even think my 8 year old daughter has ever gone that slow before.
And racing it can make a difference too, especially if there is a heads-up start, these starts almost invariably lead to traffic jams and the difference between a little bit of hesitation or a good solid start can mean that you make it out in front of the pack or get stuck in (or behind) the jam.
And with the mamba's latest firmware update, you can find other threads where people just comment it is smoother, easier to control, throttle is more precise, etc. To me it's just a combination of all these little details, Castle pays attention to the details and Traxxas is just looking for something good enough to satisfy the RTR "buy it, bash it" crowd. Little things like the LiPo soft-cutoff (with the mamba) at a voltage you set, higher or lower if you please; vs. with the VXL it is a hard-wired voltage that just kicks it back into 50% throttle mode.
#234
PA
ORIGINAL: Access
It's called crawling, or "rock crawling" sometimes, and there are whole forums devoted to it; I was at a meet today and locally the crawling meets have more people show up than the racing meets. You can knock it all you want but it's out there and the GoaT (the first system in the video) is practically the only brushless that works. There was one guy with an outrunner (sensorless) but that didn't work too well. It's either the GoaT or brushed and the control on the GoaT is simply unmatched, anyways kinda OT but you brought it up... no need to get all worked up over a 3 minute video.
ORIGINAL: vge
#235
Some people are perfectionists, it has to be perfect, an attention to detail, etc. Others invaribly turn to ad hominem attacks when someone expresses a point of view different than theirs or one they cannot understand... but it's just the way people think, expressing a different point of view doesn't have to be a threat. It just is what it is.
#236
PA
ORIGINAL: Access
#237
UT
My VXL would sometimes cogg bad as I tried to accelerate from a stop. It would cogg at speeds above what would be useful for rock crawling, I would just be trying to cruise past some obstacles at like 1-2 mph and it would cogg. Only time it didn't cogg is when I was going full-out. It was very frustrating!
I'm glad to hear they have changed their design... they shouldn't have every released that crappy one in the first place.
EDIT: Thanks Access for backing me up on the fact that it's the ESC that causes cogging. Sorry I got pissed... stupid people...
#238
http://www.youtube.com/watch?v=lCawOSqis9s
There it is... I got up to about 90% throttle in the video. That's just me doing everyday driving, not one cogg.
#239
PA
ORIGINAL: simplecj
#240
PA
ORIGINAL: Always Dreamin
#241
ORIGINAL: vge
Funny thing is, I think your going to fast to see cogging according to what people are saying. You need to be going crawler speeds.
Access, you know what you were saying about how the VXL would cogg until it finaly just stoped working? That happened to me for a while! I've had 5 of them, the first 4 didn't do that. This new one with the plugs coming out did when I got it. It would make a ticking noise, and the longer you did it, the more throttle you had to give it to get it going. Then enventually, it would just go off, and I would have to turn the ESC off then ON. I trimmed up the throttle, and it hasn't been as bad. Then again, this is the first VXL I've used with the Fasst radio, so that may be the problem.
#242
UT
ORIGINAL: vge
As for AlwaysDreamin's video, you already said you got the revised ESC from Traxxas so if they fixed the cogging issue then of course you don't have any cogging problems cause it's been fixed, duh!
Also, it seems even with the older set-up some cogged worse than others. Mine I think was particularly bad. I wasn't the electronics and it wasn't the batteries. Everything was stock electronics and I was/am using premium A123 LiFe batteries that can deliver max amperage to the ESC.
#243
I might consider buying a Mamba combo, or something... Your video was great Access. Mine doesn't do it quite as bad, but it does do it.
#244
ORIGINAL: simplecj
Now I'm wishing I'd have got some video of my cogging problems... it wan't just at crawler speeds. Crawling refers to barely moving. I couldn't even really coast around at 1-2 mph without cogging and it would even cogg just starting from a stop. I'd ease into the throlle and before the car got up to speed it would cogg, sometimes I'd even see the wheels jerk backwards before the car really got moving.
ORIGINAL: vge
#245
ORIGINAL: vge
Unfortunately chief that was their first attempt. So I am sure they did not expect it to happen like it did. But like a good company, they saw the flaw, took in the complaints and made a good fix. What do you expect? So many companies would have done nothing. So at least they have and people should respect them for that. Honestly I wonder if this cogging has to do with other issues that are related to other things in peoples electronic setup. I am going to go test my vxl setups and see if I have any of this cogging.
The terminology a lot of people use here is "cogging" = the thing shown in that video, "stuttering" is the much more common problem with a "high-power" ESC / motor pulling so much power that the battery voltage drops below the point where the ESC or receiver works and it drops out.
As for the mamba in the video, it's an optimal setup (3s and gearing for running on tough surfaces like grass). Though the VXL was just as 'optimal'. I can still get a little bit of hesistation or cogging on the starts with the mamba, even with the latest firmware, running with GP3300 NIMHs or something similar.
#246
ORIGINAL: Access
It's good they redesigned it. A lot of people rag on them just b'cos 'they're traxxas'. If you have a newer unit test it and post your results as far as the cogging. I have one of the original ones and it wasn't very hard to induce regardless of the battery setup (3s LiPo).
ORIGINAL: vge
#247
PA
ORIGINAL: Access
ORIGINAL: vge
#248
UT
Actually the amps are higher when starting from a stop. There is much greater resistance to rotation at zero or low speed, once you get moving it doesn't require full amperage to continue at that speed or to accelerate. Maximum amps are hit when you punch it off the line.
However I don't think that was my problem. I had a 10v A123 pack that can deliver up to 140 amps continuous, far more than the ESC requires and I'm sure I wan't dropping below min voltage even at max amperage to the ESC.
Also, my cogging was not just the noisy stuff where it hesistates, it would actually jerk the wheels backwards or lock them up like it was braking. And sometimes if I tried to accel too slowly then I'd get that problem where it wouldn't even move, just made some noise then turned off...
My Sidewinder has never done that, well since I got a good radio in it anyways.
#249
MI
I got my Velineon in Feb 08 and the only probs I've had is when its cold out sometimes it loses reverse (why idk). Also the on/program button will get dust in it enough to make it stick and I've had to take it apart to clean it up. For as much as I've ran it I'm happy really. I paid 139 at the LHS. It doesnt cog or stutter hardly except at redicuously low speeds. Nothign like that video. I'm no traxxas fanboy but all the LHS really carry is traxxas stuff and its just easier. and as far as speed goes I have a Slash with velineon 18t pinion and 2 of my friends have slashs with mamba 5700 with 16t pinions and all running team orion gp3900's are about dead even after a city block. The worst cogging I've seen was teh mamba 5700 with ebay special 3300's. Horrible. But that was def the batts.
#250
I hadn't even thought about getting a Velineon for my Midnight Pumpkin or Grasshopper until I came across this thread; but now I think I might! Reason: I don't really need all the programming of the Mamba, and I don't want to also change out my radio system.
For both cars I got LiPos to increase run time not to go faster. But then I found out about the low voltage cut-off thing, so got a Novak LVC. Still haven't installed it, will do so soon. The reason to consider getting a replacement ESC is
1) My stock ESC in the Pumpkin is acting up, haven't done all fault-finding yet but it is possible I need to replace it and
2) Even though I will be running the stock motor, I think it will be able to draw a few more amps from the LiPo than it could with the NiMhs I had. So, a Mamba or Velineon & LiPo & stock motor should run cooler
Any thoughts?
I have a Rustler VXL and I gotta say that I have not had any of the problems indicated by others. Maybe I am more forgiving of minor faults like low speed cogging etc. I think my solution for stuff like that is: "don't do that"
Regards
Any thoughts?
Regards
