17mm hex hub on a traxxas bandit
i have a traxxas bandit that i would like to upgrade with better wheels that have a 17mm hex hub. the only thing is i have a 5mm axle and there doesnt seem to be a conversion for it. is there anything i can do to put a 17mm hex tire on. thank you
RE: 17mm hex hub on a traxxas bandit
I have a Bandit too -
http://studysession.com/Car-TraxxasBandit1.html
If you figure it out, I'd like to know. It would be nice to use my 1/8 scale buggy tires on the rear.
CA
does it use 12mm hexs or a drive pin for wheel attachment? for the rear, there are 12->17mm adaptors you can get. the front however i don't know what you could do..
CA
o then perfect. http://rcpcrawlers.com/adapters.html. tthe black ones near the bottom. should work, depending on the axle size, you can also drill it larger if its too small
ORIGINAL: PedeBeater
The bandit has 12mm hex's on the front and back.
How do you know they changed it? I don't think they did.
TX
You can use the front Rustler axle, so that you have room to use a hex. Simple as that. That's what I did with my Bandit, so that I can use standard wheels.
the bandit i have has no hexes neither on the front or rear, but could i still use a hex adaptor for a stampede. would that be possible
ORIGINAL: sabresfreak98
so the axles are longer on the rustler as well?
TX
Actually, if I'm not forgetting something, only the front axles need to be changed to longer ones, at the rear I am able to use HPI 2.2" Super Star wheels with hexes no problems.
WI
I have the XL-1 Bandit and it has only the pins. But I think you can convert it to the rusty like I believe the one in the pics have, then you have the 14mm hexes!
WI
I compared the bandit and the rusty exploded views on the traxxas site. You need to change a few things like I think casters, axles, a-arms, tie arms. Anyway these are the part #'s that I seen different: 3631, 3641A, 3739, 3632, 3637, 3139. I'm not sure if I missed anything.
WI
Actually after looking closer to that pic it just looks like they added the rusty body mounts. That has the stock axles and I think a-arms.
