RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Looking for new shocks and foam tires
Old 07-30-2007, 06:01 PM
birel19
Default Looking for new shocks and foam tires
i need some new shocks for my X-ray t2r, I know most peple love them but mine have broken piston changers, and rusted shafts(somehow i dont know how[:@]) I was looking at the tamiya trf threaded shocks, how are they and will they fit?
Whats a good starting setup for on-road running(asphalt).
Where can i get those spoked wheels and foam tires that are good for use on 1/10 on-road cars(not carpet foams)? I have the carpet ones but they are really soft and get chewed up quickly. I just dont fnd rubber stickey enouph.LOL
Old 07-30-2007, 07:18 PM
cheech4
cheech4's Avatar
Default RE: Looking for new shocks and foam tires
i have heard people use the tamiya TRF shocks for xray replacements and love it but there have been mixed feelings about that. although the trf shocks are great there heaveir than the xray shocks and would add weight to the xray. there have been different opinions. I asked the same question and desided to stick with the xray shocks.
as far as the foam tires look into GRP and JACO they make some good foam tires from softer sticky to harder foam compounds. tower hobbies sells both brands
Old 07-30-2007, 08:07 PM
birel19
Whats is a good firm compound for the foams that will grip and last a bit? What size will i need? I have no clue about the #s, just know what looks cool http://www2.towerhobbies.com/cgi-bin...?&I=LXMWX0&P=7 i like that style but dont know what compound and size.
Any other opinions about the shocks, etc(read first post)
Old 07-30-2007, 08:10 PM
x2o
x2o's Avatar
the 26mm is the usual touring car size for 1/10th, so that will be fine. As for compound, that one looks good, I don't know to much about foams, but the description sounds great!
Old 07-30-2007, 08:26 PM
cheech4
cheech4's Avatar
those would work perfect, like i said GRP makes good foams and basically what your looking for. I think they do have harder compounds also.
Old 07-30-2007, 08:28 PM
birel19
Does anybody have a 100% percent answer on compounds? I just picked that one randomly
Old 07-30-2007, 08:33 PM
cheech4
cheech4's Avatar
ORIGINAL: birel19
im sure someone knows, but i usually look for something that says longer life, long where or something in those lines
Old 07-30-2007, 08:40 PM
birel19
i agree
What will i need to do the trf shock changeover?
Old 07-31-2007, 07:40 AM
birel19
Can someone please tell me what shore rating to use tat will will grip and last a while?
What will i need to put tamiya trf threaded shocks on my x-ray?
Old 07-31-2007, 08:42 AM
annie_himself
annie_himself's Avatar
I'm not sure about the shocks, I run the stock ones; but the harder the tire the longer it will last but it will give you less performance.
Old 07-31-2007, 11:35 AM
cheech4
cheech4's Avatar
ORIGINAL: birel19
i agree
i guess you have to figure it out, i dont know if its a direct drop in, but it can be done maybe a different screw or something to hold it, but it fits. like i said though some people like them, but some people prefer the xray shocks, look at the snowbird nationals, xray ruled there completly. insulted the other compitition, and all it was a stock t2007 and t2 and t1fko5 with xray stock shocks.
Old 07-31-2007, 01:30 PM
birel19
Okay, i guess ill just rebuild the stock shocks with new shafts and pistons, ect.
Whats a good starting setup for road racing(parking lots)?
I think im going to run these
Front- http://www2.towerhobbies.com/cgi-bin...?&I=LXMWW8&P=7
Rear- http://www2.towerhobbies.com/cgi-bin...p?&I=LXMWX3&P=
rear- http://www2.towerhobbies.com/cgi-bin...?&I=LXMWX8&P=7
should i run 26mm all around or run 26mm-30mm?
How long will a 42 shore tire last and how do they grip?
any other people know what i need to put the trf shocks on?
Old 07-31-2007, 02:06 PM
cheech4
cheech4's Avatar
it doesnt specify how long they last if you go to there website [link]http://www.grpgandini.com/uk/1-10-touring.asp[/link] you will see the harder compounds are represented by higher number and it says what kind of track ur running if its dirty or clean if its cold or warm. then look at the manufacutres number and thats the tire for the job
Old 07-31-2007, 03:53 PM
birel19
So does anybody know what things i need to put tamiya trf shocks on my t2r if i decide to use those instead. I just went to order parts and it was like 40 dollars at the least to fix mine[:'(], so might as well see what i need for the trf ones Im not really seriously rcing anyway, so i dont really mind a little bit of weight for some bling factor.
Help on what shore rating is still wanted lol
