Pede Motor Mounts Indented, Need Help!
FL
Well, I stripped my last 86T spur gear, went to my LHS, and they only had 76T Spurs. So it turns out that I now need to slide the motor closer so the pinion and spur can meet, problem is the screws have been in one spot since I got it, so it left a dent. Now when I go to tighten the screws where I need them, they slide back down to the dent. Can anyone help me please?
Thanks!
Thanks!
RE: Pede Motor Mounts Indented, Need Help!
Here is a couple of relatively simple solutions and at the bottom a link to a more in-depth solution. Just using washers would probably be the easiest route.
http://www.misbehavin-rc.com/pit-lan...otor-mount.asp
FL
thanks, will give that a try (will try the washers, if all else fails i guess i'll have to find one of those plates or make a custom one :X)
FL
found a washer and it is working great now, havn't run it yet do to some wet weather, stupid south FL. But yeah, I know it's a big difference, I got a higher pinion to make up for some of it. I will definitly keep my temp gun handy though Thanks for the help all!
ORIGINAL: 04DarkShadowGT
Going from an 86t to a 76t is a huge change in gear. You should keep an eye on the temps.
Thats what I was thinking, I went down 6-8 teeth once and my motor got so hot I felt unconfortable running it. Pinion might help though.
