6cell+1 more cell=?
RE: 6cell+1 more cell=?
A single cell provides 1.2 volts. So a 6 cell pack will provide 7.2 volts. A 7 cell pack will provide 8.4 volts. More voltage generally equates to more power.
TX
more voltage and longer run time. You go from a 6 cell pack that is 7.2v to an 8.4v with a 7 cell. Some ESC's have problems with the 7th cell so make sure your will work with the increased voltage.
Less run time, actually.... higher voltage = higher current.. less run time...
ORIGINAL: kdz76
You wont get longer run times and may in fact get lower run times with more cells. Take IB4200 cells for example. If you have 1 cell you have 4200mAh and 1.2 volts. If you wire 6 of them in series you will have 7.2 volts but still only 4200mAh. The mAh is what determines run time. The reason I say you may have lower run times with more cells is because with more voltage your motor will draw more current and drain the batteries faster.
TX
yea having a brain fart today thanks for the correction i have no idea where my head is guess I should open a window while painting and avoid the fumes
My Feedback: (23)
WI
ORIGINAL: maxxdout
Thanks for all your help. I will be getting a dtx streal esc so it can handle 10 cells, but im not sure about my motor
PA
yea, ill see what the stock gearing is when I get it. Ill do the touch test. How do ya do that again? 5 seconds=good, under 5=bad? I forgot
Right.. But everybody's pain tolerance is a bit different, someone's 2 seconds may be someone else's 9 seconds... Get a temp gun Hit up Harbor Frieght and get a cheap IR thing they have, i paid $20 a bit ago they were on sale.. works well i don't regret the purchase one second. (it also has a nifty laser pointer built in!)
My Feedback: (23)
WI
ORIGINAL: maxxdout
PA
I keep pressing the button becuse it says try me, but nothing happens LOL, yea, i think ill get thatt one as soon as i get all my other stuff for the car.
My Feedback: (23)
WI
ORIGINAL: maxxdout
WI
I just turned two venom 3000 6 cell stick packs into 1-8 cell side by side hump pack. It is way faster in my Bandit. The venom's are built like s__t anyway. They have like tin foil bars glued or something not soldered. So I used deans battery bars, deans 13 guage wire, deans connectors and decided to just make an eight cell. I am going to make a 4 cell side by side with whats left. I allready made a Y so I can hook 2 packs togeather so when I really whant to juice it I'll zip-tie the other 4-cell pack in there. I ran 12 cells with the Y connector before and I swear it's faster with the new and improved 8 cell pack? Must be the upgraded bars, whire and the fact that it's side by side now. Oh I guess I should explain why I needed to rebuild it. These batterys sucked, they constantly false peak. I would have to reset my charger like 5 times almost every time I charged them. Someone said they had the same problem and rebuilt them and no more problems. So far so good, haven't had to reset the charger at all-3rd charge now. Here's pic. I repped them in tape because these cells were bare.
PA
Here she is:
DTX Streak ESC:..........$34.99
SMC !B3600:................$34.99
Reedy Flash..................$39.99
Temp Gun:...................$21.99
Grand total of:..............$131.96
My Feedback: (23)
WI
ORIGINAL: maxxdout
Here she is:
Here she is:
My Feedback: (23)
WI
ORIGINAL: maxxdout
sadly me But my mom orders all the stuff so all i need is the money and list LOL.
My Feedback: (23)
WI
ORIGINAL: maxxdout
dunno, i might just order them from my lhs this time. They stock from tower and horizon. how much $ can i save it i do it?
