New TRF Shocks?
New TRF Shocks?
I just got my set of TRF's in today. I noticed a few differences between them and the set that I already had. One being that the shafts look like Titanium Nitrade. The other was that the shock bodies are black, with blue anodized caps. The adjustment rings are pretty nice. The only thing that seemed wierd, was that they retaining cups are made out of plastic instead of aluminum like my previous TRF's.
I may take a couple pictures during the build if there's interest in it.
RE: New TRF Shocks?
ORIGINAL: Lunchboxer
Good to know, good to know...
Be sure to post the pic of the M-03 when you are all done!!
RE: New TRF Shocks?
Well I've got them installed. They are really sharp looking, and very smooth. For my M03 I'm running 3 holes in the front, 2 in the rear and 35W oil all the way around. Now since the springs that come with them are a little too long for the M03 I had to use my springs from the stock oil dampers that come with the M03R. These are definately some of the best shocks I've ever seen.
On a side note. I really like the adjustment collars on these. I think I may order a couple sets for my Xray's.
RE: New TRF Shocks?
Very nice.. I use the stock springs.. argh! Maybe my M-03 is too high.. ha!
RE: New TRF Shocks?
i have a few sets of TRF shocks and retainers have always been plastic, i know they are available as a hop up though, and yours are by far the coolest looking!
RE: New TRF Shocks?
I have never ran it on a surface w/ traction high enough to flip over!!
Oh yeah, I have silvercan in my M-03.. ha ha ha!! i.e., not super fast! (does have the blue TRF shocks, though.. ha! w/ the stock yellow springs) I am thinking I should find some short springs...
RE: New TRF Shocks?
RE: New TRF Shocks?
Anyway for you to take a pic of the springs that came w/ your TRF vs. the short spring?
Because when I built mine, I know my TRF shocks come w/ spring that's the same length as the one that came w/ my M-03M.. which, comes w/ different shocks than your M-03R, I am sure...
RE: New TRF Shocks?
RE: New TRF Shocks?
Thanks!! I think I should get some shorter springs!! Ha!
Did you put some spacers inside to limit the down travel?!
RE: New TRF Shocks?
My M-03M is having some setup issue.. if you push down on one of the front shocks, say left one, the right rear would leave the ground, and vice versa.. BUT, the pressure needed to get one of the rear wheel to lift up is different.. so when I drive, I have different degree of off-throttle oversteer.. on one side, it turns better, but on the other, it does not turn as well..
Very odd..
I re-checked the chassis and everything seems to be straight and all.. (using my caliper and measure, etc.) Pretty strange....
Very odd..
RE: New TRF Shocks?
Very odd..
Very odd..
. As for the pressure difference to the one side. That sounds like it has to be in the shock somehow. Something binding or dragging, maybe catching on the chassis somehow. I know there isn't a lot of space between the chassis and my shocks.
RE: New TRF Shocks?
Hmm, no binding.. all shocks are built correctly (I think!) as they are not my first TRF shocks.. caliper was used to make sure all length are the same.. o-rings were used to limit the down travel..
I did not mean that it takes different pressure to push down the shock.. I meant, it takes different pressure to push down the shocks (front) in order for the rear opposite tires to move off the ground.. odd, isn't it? It is like the chassis is tweaked or something.. ha!
Here's some pics:
http://www.rcuniverse.com/forum/m_52...14/key_/tm.htm
ODD.. ha!
Here's some pics:
ODD.. ha!
