RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Rustler Body
Old 08-08-2007, 09:28 PM
LiL Richy
LiL Richy's Avatar
Default Rustler Body
Would this fit the rustler if i drill some custom holes? http://www2.towerhobbies.com/cgi-bin...?&I=LXRRE9&P=7
Old 08-08-2007, 09:42 PM
kdz76
Default RE: Rustler Body
the specs on the body are
SPECS: Length: 16-1/2" (419mm)
Width at widest point: 6-1/2" (165mm)
Height: 4-5/8" (117.5 mm)
and the rustler specs are
Length 17.5 inches (445mm)
Front Track 12.25 inches (311mm)
Rear Track 12.25 inches (311mm)
so off the bat the body length should be close as the body doesn't go fully from front to back and the track is over all width best thing to do is check the stock body for size and if its close enough you can custom fit it
Old 08-08-2007, 11:21 PM
x2o
x2o's Avatar
Here's the dimensions of the stock rustler body (taken from tower hobbies)
SPECS: Length: 16-1/4" (413mm)
Width: 5-1/2" (140mm)
Height: 4-3/8" (111mm)
And here are the specs for the pro line one you linked :
The pro-line one is actually bigger than the stock one, so it will fit. It might look a little funny, cause there's a whole 1" difference in width, but other than that, it'll fit as long as you drill out new holes.
