Will this be able too work?
IL
Ok i want to put this http://cgi.ebay.com/Mamba-1-10th-Sys...QQcmdZViewItem on mu rc10t. My tranny is built good.
Thanks: savycharlie
Thanks: savycharlie
RE: Will this be able too work?
ORIGINAL: loganb
hey thanks for the link i guess ill bid on it!!
just kiddin
just kiddin
TX
If your RC10T is actually an original 10T and not a more modern T3 or T4 I'm afraid the 7700 motor is too much as in too high rpm and low torque = too much heat issues. Actually, I would not recommend the 7700 for a stadium truck, a buggy would be fine. But a truck is pushing it on the heavy side of things. But if you're gonna run lipo, then hopefully the lighter weight might help, if you gear it the heck down with the smallest pinion you can find. Then run it and check the temps and go up in pinion size until you're happy with the performance and heat.
