Dual Brushed Motors On Mamba Max ESC?
Anybody run dual brushed motors on a Mamba Max ESC?
Need an ESC for a Clodbuster, want to run dual 17T brushed motors.
RE: Dual Brushed Motors On Mamba Max ESC?
I'm interested in a definate answer too! Does the MM ESC even have a turn limit for one motor? I know is has a 100 amp rating, so as long as you don't exceed that with both motors, you should be fine, right?
CA
it should work fine. experimented a bit with no problems. also read people running dual motors on various other forums
