Slipper Clutch problems
I went to the park and took my vxl rustler out on its first run. I was having performance problems and what it turned out to be was the slipper clutch. With the help of other posters I found this out and corrected the problem. Now the truck runs great! I got a 28 min. run in today! With no performance problems at all!!
RE: Access was right! Do not get a 4000 mah lipo!
Did you reset the mesh when you pulled it out of the box new? I've heard a few accounts of the mesh being poorly configured from the factory. As for the 11.1v going 7 minutes, that sounds a little low to me... Was that the first run with this battery?
I just finished charging the battery and it charged 1659 mah. So that means I had 2341 mah left in the battery. Thats more thans half. So why did the speed of the truck go down so much so soon? It was like i wasnt getting much power out of it at all and I did try reconnectiong the battery only to lose the speed again in liek a minute. This is all probably because of the esc. Should I turn the esc off?
ORIGINAL: hunter306
No i didnt reset the mesh... im not sure how to do that im pretty new to all of this.
That doesn't sound right for run time. I get over 20mins of runtime in my mini's with brushless and lipos. I also get close to 20 mins of runtime with a 6 cell 3300mah NIMH in my Stampede with a Mamba Max 4600kv setup.
Well I guess its not the battery cus i charged it and the battery still had 2341mah still left in it when i stopped the run. So i guess its not the battery its the esc that if up the speed.
What type of charger are you using? Do you have a balancer for the Lipo? Check to make sure there isn't anything causing the drivetrain to bind up. What does it do when you are holding the truck and give it some throttle? The gear mesh is how the pinion gear and spur gear come together.
Yes, you should look at the charger as to why your only putting 1659 into it. If it has an adjustable peak detection, look there (thinking outloud; when charging a lipo, is there EVEN a peak detection??)
well i put in 4000 max to charge. It beeped and it was done. I think it only put in that much cuz thats all it could put in
if your new to this why not title the thread better, you make out its the lipo that is the problem, and from what you have wrote i doubt this is the case.
ORIGINAL: Jerohmeee
I ran my vxl rustler today in the park in the grass and yup access was right about the 3 cell 4000mah! I was lucky to get a 10 min. run out of it! I'd say 7 min. into the run the power went drastically down. I let it rest and started again and the power was good maybe for like a minutes and then went down the ****ter again. If i hit tall grass the thing would barely even move. It sounded like the motor was going but the wheels werent turning.
Now i checked the temps and the motor and battery were ok but there was smoke comming out of the gear cover. I took a temp. of the gear cover and that was like 170. So is this normal for smoke comming out of the gear cover. I went home and took the gear cover off and the gears looked fine. None of the the teeth were stripped.
B'cos your battery still had more than half the charge after the run, you're seeing a different problem than I was and it might yet be fixable. Was the battery super-hot at the end of the run?
Smoke is never 'normal'. Especially with an electric.
no the battery was not hot at all.... ya ther was def. smoke comming out from the gear cover. the gear mesh looks alright. Like i said the spur's teeth r like halfway down into the pinion teeth. The slipper... ya i have no idea how to tweak that.
NY
ORIGINAL: Jerohmeee
my guess is if the smoke is coming from the gear cover then the slipper is too loose and its spiining like crazy and burning up the pads quickly, i suggest you follow the manual and tighten up the slipper all the way and back it off 1/2 turn i think thats what the manual says, that at least would take care of the smoking problem.
TX
You should change the title. The battey has obviously NOTHING to do with the problem you're having. Other than the fact that it's supplying all the power your motor wants.
Slipper is slipping too much, man. Tighten it. Also, just because it's peaking at a low number, the remaining mAh it didn't charge isn't the mAh you had left (always). It could be a false peak. You mentioned when the power started to get lower, you let it sit off for a bit, and turned it back on. If the battery was pretty much discharged, you can over-discharge the LiPo which can damage it, possibly explaining false peak or not getting all that mAh in.
