Losi Lithium Charge Converter
My Feedback: (23)
WI
Here it is...
http://www.teamlosi.com/Products/Def...rodID=LOSB9607
I was notified by a friend about this and I am seriously concidering buying it and using it on my Piranha Peak digital charger. This makes me want to try lipo/limn/liion so bad. What do you guys think?
NJ
RE: Losi Lithium Charge Converter
hey im "a freind" if only it balanced too.... darn... if this is any good i can get a lipo charging setup for 60 bucks or less, 30 on a nice charger from SAD, then this little peice of heaven..
i wonder why no one else came up with this, bc losi doesnt really do lipos..
My Feedback: (23)
WI
ORIGINAL: t9dragon
I wouldn't get it. It is better to use a charge designed for Lipo's...............
My Feedback: (23)
WI
If I do get the converter Ill most likely get this balancer- http://www2.towerhobbies.com/cgi-bin...&I=LXMGS7&P=ML
Since its made by Great Planes and that its a very reasonable price.
ORIGINAL: Takedown
$30! You cant pass on it! If it doesnt work Ill end up getting the Super Brain 989.
ORIGINAL: t9dragon
My Feedback: (23)
WI
ORIGINAL: t9dragon
I would just spend the extra $20 and get a Quattro Plus 2-3 lipo charger.
ORIGINAL: Takedown
ORIGINAL: t9dragon
My Feedback: (23)
WI
ORIGINAL: t9dragon
It is an AC/DC charger. Here is a link to the charger http://www.ripmax.com/item.asp?itemi...0&Category=070
My Feedback: (325)
http://www.slkelectronics.com/lipodapter/index.htm
Consider this also. It has been out a long time and I hear it works good. The tutorial is a nice one.
My Feedback: (23)
WI
ORIGINAL: guver
I also use this balancer on my Lipo's http://www.commonsenserc.com/product...roducts_id=184
and this lipo voltage tester http://www.commonsenserc.com/product...roducts_id=331
NJ
ORIGINAL: t9dragon
ORIGINAL: brushlessboy16
that charger uses a jst plug with small wires, its not designed to charge at faster rates, its maxx is only 3 amps....
ORIGINAL: t9dragon
I also use the the Multiplex LN5014 charger which is $80 and then you need a power supply.
Both charges take the same amount of time to charge a 2s 2100mah lipo.
My Feedback: (34)
I'm interested in going lipo too, and you're better off to just get an all in one unit like hwshadows mentioned. When you add up the adapter, equalizer, and anything else you may need it'll be the price of a cheap lipo charging unit anyway.
ON, CANADA
If you can charge at a faster rate you can spend less time charging. I wouldnt want to be limited to 3 amps if I had a 6000+ mah pack.
NJ
ORIGINAL: t9dragon
Why would you want to charge at a faster rate?
ORIGINAL: t9dragon
if you have a 4000 mah battery u can charge at abouyt 1.1c, do 4.1amps, less down time, thats why u wanna charge faster
