MAMBA MAX 5700
MAMBA MAX 5700
where is the cheapest place to buy the MM5700 including delivery to the UK?
thanks in advance Luke. (oh this will be going into my M-03R by the way)
RE: MAMBA MAX 5700
what ESC's will work with this motor?
http://www.apexmodels.com/product-se...ories&id=13854
and how much inc postage to the uk?
RE: MAMBA MAX 5700
ORIGINAL: t9dragon
You can use the Mamba Max ESC with it.
PA
RE: MAMBA MAX 5700
I liked my 7700 fine, other than the shorter runtimes. The speed from it was incredible, and as long as it was geared correctly, heat wasn't a problem. If you're just looking for flat out breakneck speeds, the 7700 is a fine motor.
J.
J.
NY
RE: MAMBA MAX 5700
i have a 6900 in my losi and i race against my friends b4 buggy with the 7700 all the time, both on 6 cells the speed is not much different, but i do have slightly better run times. i say 6900.
RE: MAMBA MAX 5700
ORIGINAL: AutoXMan
lol, that should be a site to see, take some video when you do that!
ORIGINAL: rcluke
this is going into my M-03R on a small carpet track, with rubber tyres
