RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Official E-FIRESTORM thread
Reply
Old 06-26-2009, 03:04 PM
  #2701
jasvic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Official E-FIRESTORM thread
My Flux arrived yesterday, and so did my battery and charger from Hong Kong. Amazing timing. Wanted white, came in red...oh well, bad luck. Want to get a clear body anyway and be creative. Co-worker who got me into this soldered a Deans connector to the battery for me. During lunch, we took it out to a local little league field and watched it kick up a ton of dirt, running the bases and hopping the pitcher's mound. Good times. Only had it out for 15-20 minutes, but had fun.
In the parking lot the thing does wheelies at the drop of a hat. Too lazy to search the thread right now, but where did you get your wheelie bar? And does it keep the truck relatively low?
jasvic is offline
Old 06-26-2009, 08:38 PM
  #2702
Paron34
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just loosen you slipper clutch a little should help alot with the wheelies !!
Paron34 is offline
Old 06-26-2009, 09:48 PM
  #2703
e-firestormer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys, got one of those E-sky gyros from the *bay and fitted it to the flux a few days ago. Everything that has been said about them it true! The flux is like a rocket with the gyro. You can drive flat out on slippery surfaces and still track straight. When it stops raining outside I will have to try it on the gravel. It gives it the straight line stability of a 4WD!
I have seen aluminum steering bits for the T4 on *bay and they look pretty similar to the ones on the e-firestorm. Has anyone tried to see if they can be modded to fit?
What is better, toe-in or toe-out for the front wheels? I see some trucks setup one way, and other the other.
Cheers,
David
e-firestormer is offline
Old 06-27-2009, 12:12 AM
  #2704
Paron34
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice my New Novak Havok3's Ballistic 8.5T just got here ,was on back order from A main hobbies !!! I'm going to buy a bag of pinion gears tommorow ranging from 15 to 21 tooth"wont need past 19". Gonna post some pic's tommorow after I get the right gearing.
Paron34 is offline
Old 06-27-2009, 12:43 AM
  #2705
redfisher1974
redfisher1974's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jasvic
Thats cool...My wheelie bar is off of ebay...bonzi bar or something like that.just type in E-firestorm and it should come up...and it does keep it low..maybe 4 or 5 inches off the ground.
redfisher1974 is offline
Old 06-27-2009, 12:44 AM
  #2706
redfisher1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: e-firestormer
Cheers,
David
I run the esky gyro too....works good..
Old 06-27-2009, 12:47 AM
  #2707
redfisher1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awsome....lets see some speed runs.
Old 06-27-2009, 03:13 PM
  #2708
jasvic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, if I did this right, here's some pics of my Storm in the backyard. It's a little uneven from an old pool, so i was able to get a few small jumps. Also, I took several breaks to let it cool down since it was on grass, was checking temps often. How hot it too hot for the motor and ESC?
ID:	1225707   Click image for larger version
ID:	1225708   Click image for larger version
ID:	1225709   Click image for larger version
ID:	1225710   Click image for larger version
ID:	1225711   Click image for larger version
jasvic is offline
Old 06-27-2009, 05:25 PM
  #2709
redfisher1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
over 160f is getting hot...
Old 06-27-2009, 05:54 PM
  #2710
kilimats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Follow up from my Tactic Tx/RX review quoted below
The Car is faster and gives smoother acceleration, I can wheelie while doing 20mph while before I had to be stopped or running very slowly ( I did the comparaison with same tire/road condition/clutch setting). And driving slowly is easier than before since the throttle is way more sensitive and the Receiver capture all that data without interference
TOP speed seems to be higher as well, I have to double check in an open field next time
The braking is very similar, I do not notice any difference even so the reverse throttle has less travel compared to stock
"you get what you pay for" does not apply to this product, AMAZING value ! Highly recommended !!
Fun side note: I can actually maintain the wheely without wheelie bar, just gliding on the rear metal skid plate and keeping the throttle speed balanced, pretty dope !! (not doable with stock FM Tx)
ORIGINAL: kilimats
First Impression of the tactic 2.4Ghz TX/RX combo from Hobbytowers after a few minutes run (currently @ $80ish with RX)
Pros
Awesome range !!!!!
Interference free !!!! (in my street, stock was loosing signal after 20m, 2.4ghz keep going forever)
Failsafe built in, OMG finally I can drive worry free !
Smoother acceleration and perfect precision even far away (barely see the car)
lighter TX/Rx
Smaller Rx
only 4 AA required
No more gigantic antennas
CHEEEEAAAAAPPPP !!!!!
Cons
Plastic quality a little under the stock TX
often out of stock at towerhobbie (I waited 3 month)
The reverse has a little less play so the car cannot go as fast as with stock TX (still pretty quick anyway), the forward has more play though, not sure if it goes faster, will check
Conclusion: a MUST buy for the failsafe alone !!!
not sure what the RX battery is for, I didnt need it to run the car (see last picture)
kilimats is offline
Old 06-27-2009, 07:42 PM
  #2711
redfisher1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
awsome...I want to get one for my VXL slash...The stock am radio is too touchie at 50mph.
Old 06-28-2009, 07:51 PM
  #2712
redfisher1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I must say this 1/16 VXL slash is fast as hell..to the point you cant keep it on the ground.....But after playing with it and going back to the storm,makes me like the storm even more...
Old 06-28-2009, 09:30 PM
  #2713
Paron34
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: kilimats
''you get what you pay for'' does not apply to this product, AMAZING value ! Highly recommended !!
ORIGINAL: kilimats
Pros
Awesome range !!!!!
lighter TX/Rx
Smaller Rx
only 4 AA required
Cons
Is the wheel rubber of plastic like the stock receiver ? can't really tell from the pic's. Im about to buy a new radio its between this and the Spectrum 2.4 DX2.0
Paron34 is offline
Old 06-28-2009, 10:08 PM
  #2714
kilimats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Paron34
Yes, the wheel feels about the same as OEM
kilimats is offline
Old 06-29-2009, 09:21 AM
  #2715
redfisher1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dropped down to a 18t pinion on the storm....seem to get a longer run time...
Old 06-29-2009, 11:25 AM
  #2716
sheik480
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How would a gyro affect a four wheel drive offroad rc? It obviously wouldn't be needed for takeoff control, but I imagine it would help on rough ground and turns on slick surfaces. Any input?
sheik480 is offline
Old 06-29-2009, 11:42 AM
  #2717
redfisher1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am not sure....if you try it let us know..
Old 06-29-2009, 01:27 PM
  #2718
sheik480
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will do!
sheik480 is offline
Old 06-29-2009, 04:00 PM
  #2719
bvr_j_0969
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking into getting a firestorm flux, but i dont race, and there is nowhere to race around here nor enough people, So i mainly just bash, maybe race a buddy around a little, but wondering, is the firestorm flux built to stand up to some hardcore bashing? that all i really want is a good fast bashing rig. if not anyone have any suggestions to a good basher?
bvr_j_0969 is offline
Old 06-29-2009, 05:17 PM
  #2720
Paron34
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Nephew ,Nephew's wife, and his father "my brother in law" all got traxxas and losi rig's the same time I bought a E firestorm 10T. They have all broken parts !! me none what so ever. Stock I also seem faster in dirt with much better handling than the Rustler's. I toasted my Nephew's wife's SpeedT with the New Ballistic 8.5 with 18 Pinion gear off road track diffently seem's like the FS can handle to the high speed's better than its counterpart's. Gonna post some pic's of my back yard stock race's soon as my wife gets back with the camera from work. But to answer your question the FS is a "Great" 1/10 scale basher !!!
Paron34 is offline
Old 06-29-2009, 07:40 PM
  #2721
tokzik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the firestorm flux is the best basher i ever had... i have yet to break a part !!! and trust me i bash the heck out of it. but i have managed to ware out the bumper motor protector .
ok so i got back from racing at the the club this weekend with my firestorm flux.. and started to get real annoyed at the lack of people marshaling, i spend a lot of time doing it for other people but not many people seem to bother sooo and after thinking it over i have decided to have a go at making a rig to flip my car over for me ... ill make some pics of my progress if anyone is interested
so far i have managed to draw out my plan and ill be hunting for parts tomorrow.
on a side note, im interested in a little more torque, anyone got any suggestions for a motor, i only run 2s and i have heard the Xcelorin 4800KV Brushless Motor may be just what im looking for with 2s lipos
any thoughts ??
tokzik is offline
Old 06-30-2009, 08:41 AM
  #2722
redfisher1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you could go down a couple teeth on the pinion for more torque...if you dont mind losing a little top speed.
Old 06-30-2009, 08:53 AM
  #2723
kilimats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: tokzik
any thoughts ??
Do you have the stock flux or a custom one ?
I run the stock flux and find the torque outstanding, wheelies at any low speed using a 2.4 Tx and sticky clutch.
kilimats is offline
Old 06-30-2009, 09:41 AM
  #2724
jasvic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So last night I spent some time flipping the rear arms to increase the wheelbase. Sci-fi was showing Star Trek TNG re-runs, so it was a good time. When I was finally finished, it was pretty dark outside, but I was impatient and wanted to just test it out on the concrete, adjusting the slipper until the front would just barely lift.
Once done that, I thought what the heck, and ran it in the yard for a minute or two. Bad idea, when I brought it inside and set it down, I found it picked up quite a few slugs and other critters. Fortunately, I had some newspapers laid out so it was contained. Had to go over it real well to make sure it was bug free...a couple were on the inside of the wheels. Not good times.
The moral of the story is, don't run it in grass at night on a humid summer night.
jasvic is offline
Old 06-30-2009, 10:06 AM
  #2725
redfisher1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yuck...slugs....lol
Contact Us Archive Advertising Cookie Policy
